I'm new to the C4 world and just got an 89 coupe. I had all of the fuel injectors replaced and now I've noticed that the car wont return to a decent idle. If I tap the gas it will go back down but when I drive it tends to "stick" at a higher RPM.
Any suggestions on how to deal with this? Thanks in advance!
I would check the throttle body linkage for binding and make sure the TB itself is clean. If you provide some info on the car in your profile our forum technical guru's will be able to help you more. Good Luck!
