passive Keyless entry
Old Nov 14, 2007 | 06:40 PM
ARMAN72's Avatar
ARMAN72
Default passive Keyless entry
I just got my car back from the shop havin the opti, water pump, plugs and wires replaced, I get in it to come home and that light is on...and its not going off even with the car shut off in the garage! what the hell is up? my remote died about a month after i got it and this light has never been on before but at start up..PLZ help!
Old Nov 14, 2007 | 09:32 PM
ARMAN72's Avatar
ARMAN72
no one have a clue?
Old Nov 14, 2007 | 11:07 PM
ARMAN72's Avatar
ARMAN72
i talked to a few buddys of mine could the guy have forgot to plug somethin back up when he did the work? anything come on guys lol
Old Nov 14, 2007 | 11:32 PM
lt4obsesses's Avatar
lt4obsesses
First, I would try disconnecting the negative battery cable. Let it sit for 5 min and reconnect it. This might reset the pcm and see if the light goes off. Secondly, get a new battery for your fob. I seem to go through on every other month. They say they should last for 18 months, but that is not my experience. I usually get mine at Wal-mart, about $4.
Old Nov 14, 2007 | 11:54 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Presume you mean the 'Passive eyless Entry' lamp on/in the DIC.
Might this be the first time the battery has been disconnected for a long period of time since you lost the remote FOB (presume the mechanic disconnected the battery while working on the car)?
Any chance the mechanic left something plugged into the DLC (plug below the driver side dash)?
Have you tried disconnecting the battery for 30 minutes and reconnecting it to see if the light goes out?
Have you an FSM? Have you tried to pull the PKE DTC codes?
Assuming your 1993 is the same as our 1994, pulling the codes can be accomplished by grounding pin # 8 in the DLC (e.g. connect a jumper wire from pin # 8 to pin # 4 or 5 as both are 'grounds')?
Let us know...
Old Nov 15, 2007 | 12:47 AM
ARMAN72's Avatar
ARMAN72
i have never used the fob, it didnt work right when i got the car, so i trashed it......
To passive Keyless entry
