Fuel Filter Install **** Up
So, yesterday, I changed it. The first thing I did was to disconnect the fuel pump by unplugging it under the gas door. Then started the car and let it run until it died (out of gas). Then, I jacked the car up, got a drain pan and a couple of rags ready and proceded to remove the fuel line.
Here's where I messed up. I took the return line apart to get better access to the filter since there's not much room to get a wrench in there. BAD IDEA! The return started siphoning the gas out of the tank. I had to scramble to get a rubber cap on it to stop the flow. I lost at least 1/2 a gallon.
Now I'm laying on the floor with gas running down both arms, dripping off my elbows. TIME-OUT! Got me and the area cleaned up, then I got the filter off. (Seemed nearly impossible if I didn't have crows feet wrenches.)
Put on the new filter and got all the lines put back on. (More gas and more clean up.)
Started it up. Sounded good. Took it out for a drive and it ran great. Glad that's not something that has to be done very often.
(Why does this kinda crap always happen?)
Last edited by johnnymo63; Nov 15, 2007 at 08:53 PM. Reason: Omiting questionable words
not gonna say I told you so cause we didn't discuss it first............but now I told you
I only buy fuel at newer gas stations (that have newer tanks) because I hope I don't have to change it again anytime soon!
Take Care Everyone, -John
I followed the advise and let me tell you, this is no fun job!
I have a 94, so catalitic converters are on the way. I tried removing the catalitic converter and after some hard work forgot that the cat converter is also secured to the clutch bell housing!
So I assembled back the nuts I removed.
I went directly to the fuel filter, very tight quarters, my backup wrench would not fit, curiously it did with the replacemente fuel filter, so I used an adjustable wrench to hold it.
The flair nut wrench would fit to the fuel line but no space to turn it.
So I grabbed a stuby wrench (16mm) and gave it a try. After a lot of effort I got it loose and hell started.
Fuel was dripping everywhere, got fuel all the way to my armpits, darn it hurts!
And after maybe 1/4 gallon it only dripped a little.
I coud not fit the wrenches to remove the front part so I used the stubby wrench to hold the nut at the fuel line and used a tool to remove directly from the fuel filter nut wich by the way bent.
After I released the fuel filter I could unscrew it and noticed that there was no way I could have turned the nut at the fuel line. There was some kind of black gummy plastic over it that froze the part.
I screwed the filter back and then the fuel line at the back, tighten, checked for leaks and the nightmare was over.
Very difficult job, I did not enjoy it, and hope not to repeat it in a near future.
By the way I cut open the used filter and it was very clean.
I guess it was not that necessary, although I have 35k miles on the car.
PrOzac is right!!!!!!!!!!!!!!!!!!!
Don't mess with the thing until you pull the motor. Better yet, don't mess with it until you do a frame-off restoration (My Opinion)!!!!!!!!!!!!!!!!!!!
In any case, This job 'Ain't nothingNice'(as we say in the south).
Take Care and BE REAL PARTICULAR WHERE YOU BUY YOUR FUEL!!!, -John
Last edited by Johns87; Nov 15, 2007 at 10:34 PM. Reason: spell pozac's name right.
God's way to keep us humble.
