automatic shifters
Old Nov 19, 2007 | 10:54 AM
clay69's Avatar
clay69
Default automatic shifters
Hi all I have a 96 CE and want a aftermarket shifter so I'm trying to find out the difference in the shifter between say a turbo 400 or a 700R4 and say a
4L60, and 4L60E they are all cable shifters as far as I can tell.
So with some modification I should be able to use a shifter from a turbo 350 or a 400 right?
I mean as long as it is a 4 speed automatic shifter.
I may have to change some mount points or things like that but the mechanics should be the same right?
thanks
Clay
Old Nov 19, 2007 | 11:03 AM
aminnich's Avatar
aminnich
Since all shift points are PCM controlled on your 4L60E transmission I am not sure what you are trying to achieve. If you want to change shift points then either get the PCM custom tuned or get a Hypertech power programer.
Old Nov 19, 2007 | 11:29 AM
l8rdays1's Avatar
l8rdays1
Good luck as I tried to find one for the 93 . With out cutting the consol up.If you find one that will work post it as no luck here.
Old Nov 19, 2007 | 11:38 AM
clay69's Avatar
clay69
I like the 4 speed look nothing more then that..
To automatic shifters
