heat only works sometimes
Old Nov 20, 2007 | 10:22 AM
white1984Z51's Avatar
white1984Z51
Default heat only works sometimes
The heat in my 1984 will work sometimes, sometimes it will not. Does the low coolant sensor have some sort of connection, if so where does it come from? I can't find any type of connection, thought this might be the problem.
Old Nov 20, 2007 | 10:49 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
LC sensor is for the display... get a FSM for diags and repair...
Old Nov 20, 2007 | 04:05 PM
thebeerman's Avatar
thebeerman
Yeah, get an fsm. could be air in the system or some blockage (especially in an older car that someone may have used a radiator sealent to keep the heater core from leaking!). I would also try a power flush.
Old Nov 20, 2007 | 04:17 PM
hmcquade's Avatar
hmcquade
I have an 84 and my heater was not working correctly. It turned out I had a bad vaccum leak in the Heater/AC Control Unit. I got a NOS and it replaced.
Hugh
Old Nov 20, 2007 | 05:50 PM
schrade's Avatar
schrade
Core blockage. I put $5 on it...
http://forums.corvetteforum.com/show....php?t=1861337
Old Nov 20, 2007 | 06:03 PM
4CAM LT5's Avatar
4CAM LT5
St. Jude Donor '09
Basically, the same quirk / problem with my '89. I've got the auto climate control set on "90"...and barely any heat. Every so often, the "Low Coolant" will intermittantly come up on the screen, and the air coming out of the dash vents will go pretty cool. Then, the "Low Coolant" notice disappears from the screen, and air from the dash vents begins to warm a little. Any of this 'related'?
Could it be the programmer board (near gas pedal, I understand), or, more likely something in the heater core...?
Old Nov 21, 2007 | 10:07 AM
white1984Z51
what is an fsm, ? service manual?
To heat only works sometimes
