Driveshaft Length?
Old Nov 25, 2007 | 01:28 AM
texasedirpvette'91's Avatar
texasedirpvette'91
Default Driveshaft Length?
Im Replacing My 700r4 Out Of My '91 L98, With A Zf6 I Bought. Since Im About 4,000 Miles Away From My Car For Now, I Cant Measure. Can I Use The Same Driveshaft With The Swap? and if you know a place that sells aluminum driveshafts, please let me know. thanks
Old Nov 25, 2007 | 03:52 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
You can use the same drive shaft if you still have your D36, you just have to change the yoke.
But if you installed a D44, then you need a shorter driveshaft.
Old Nov 25, 2007 | 05:55 AM
texasedirpvette'91
perfect, thank you
To Driveshaft Length?
