Hypertech Performance Module on 96 LT1
Old Nov 28, 2007 | 04:13 PM
vetter31's Avatar
vetter31
Default Hypertech Performance Module on 96 LT1
For anybody that attached the Hypertech Performance Module (HPM)on a 96, automatic, LT1. It appears that when the HPM is on the car, some of the digital mileage or distance remaining, or mileage computations are not correct. Take the HPM off and I think it goes back to being correct. Not a bad thing, just a little annoying. Has anybody else noticed this or is it me?
Old Nov 28, 2007 | 06:29 PM
95!Vette!'s Avatar
95!Vette!
I have one on my car explain your situation a little more clearer what is happening any problems ??
Old Nov 29, 2007 | 09:43 AM
vetter31's Avatar
vetter31
No real problems. It just seems that the mileage computations are not working properly. The HPM really makes a lot of difference in the performance. The RPM switch sort of scares me a little. RPM is raised about 400 PRM in low gear and a little less through the other gears before shifting.
Old Nov 29, 2007 | 12:52 PM
redcorvette96's Avatar
redcorvette96
That stuff doesnt work. Gordon Kilbrew said that stuff is snake-oil.
Your Corvette will run worse, run rich, could burn out your catalytic converters and will make your gas mileage worse.. Also your Corvette will probably run slower. Leave it stock!!!!!
To Hypertech Performance Module on 96 LT1
