Spring upgrade kit is for the front. The later model c4's had aluminum spring brackets that when you installed to lowering wedges on the your springs, you cut the brackets down accordingly. Otherwise the spring will move up and down in the bracket. You can find the later model brackets here and sometimes Ebay. Will save you a bunch. On the rear you just install longer spring bolts to lower the rear. Hope this helps.
I understand I can get the bolts seperately
But if I bought this bracket for the front off ebay I would still need the wedges ...
I just dont completly understand the bracket, why would i need it if there isnt one now ?
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The retainers need to be snug on the spring to keep it located and prevent tearing the wedges off. When you use the shorter wedge you need to get the aluminum clamps and shorten them (because your steel ones can't be shortened easily).
Most people don't bother, but IMO they are half-assing it to save $45. It'll take you all day to do the work so why not do it right? Doing it wrong and having to redo it always takes longer and costs more.
Also note, some choose to glue the wedge on the spring, some glue it to the frame. I can't give you an answer either way on which is correct.
Hey Corvette dan
90 plus shipping its not a bad deal at all,i think i will get this kit real soon !!
Please let us know how you did it and how your vette looks now
thanx !
