Headlight door adjustment???
Old Dec 4, 2007 | 10:34 PM
Vet76te's Avatar
Vet76te
Default Headlight door adjustment???
I just got a 1985 Vette. One of hthe headlights sits down too low on the front edge. It opens and closes fine, just the front edge is dipped down too low on the front.
Is there a simple adjustment to correct this?
Old Dec 4, 2007 | 11:26 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Remove the lamp cover and you'll see four 10mm bolts on the back side of the lower cover. Loosen and adj.
Old Dec 5, 2007 | 01:37 PM
redrose's Avatar
redrose
but if front is low and rear is high, reset the stop on the rotating bucket (framework)
Old Dec 5, 2007 | 01:57 PM
Vet76te's Avatar
Vet76te
How do I reset the stop?
Old Dec 5, 2007 | 03:46 PM
zr1fred's Avatar
zr1fred
Two screws, both on the front of the light assembly control the stop position.
To Headlight door adjustment???
