Another problem fixed....MEEEEEE
Old Dec 12, 2007 | 10:52 AM
arizonaames269's Avatar
arizonaames269
Default Another problem fixed....MEEEEEE
I just fixed the light dimmer switch. I learned that you turn it CCW to brighten and CW to dim
Old Dec 12, 2007 | 10:56 AM
86PACER's Avatar
86PACER
Yeah, I dumb azz replaced the wiper motor. Only to realize that you have to press the slide button down on the switch, not just slide it down to activate the spray. Getting that motor tight back onto the reservoir is a PITA. Worse is doing it when you did not need to
