6th gear noise
Old Dec 13, 2007 | 11:22 PM
FOXX's Avatar
FOXX
Default 6th gear noise
Not a bad or very noticeable one but enough for me to be concerned. Is this normal? Anyone else notice that 6th is louder than the rest of the gears?
Old Dec 14, 2007 | 12:10 AM
RRT vette's Avatar
RRT vette
I haven't noticed 6th sound any different than the others. From what I have read from other owner, is that it is common for the ZF6 to have some whine to it.
Old Dec 14, 2007 | 12:49 AM
FOXX's Avatar
FOXX
That's what I thought. I know some manual trannys have that whine to them but was just wondering if anyone else has experienced it. Thanks.
Old Dec 14, 2007 | 09:06 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Mine does not make any noise or "whine" in 6th.
Old Dec 14, 2007 | 09:33 AM
tomtom72's Avatar
tomtom72
Active Streak: 90 Days
St. Jude Donor '08 thru '26
the only noise is in 1 thru 4, after that the gears are bevel or spiral cut vs a straighter cut in 1 thru 4. Maybe go to zfdoc.com and look around a bit in the Q & A section or drop Bill a note.....he's a waaay nice guy and always trys to lend his knowledge.
One thought, not a very good one either.....6th & reverse have an oiling issue in the stock trans....Bill's rebuild addresses that issue. I'm no trans guy, but I think the issue is with the bearing for those gears(???) but don't quote me. Most of the "failures" in the zf box are either syncros going bad from bad hydraulics and this thing with the oiling in rev & 6th.
Tom
Not to be insulting....just a Q...how's the fluid level & condition? Low fluid and or old fluid will make for whinning noises.
To 6th gear noise
