Help With Bigger Tires
Old Nov 25, 2001 | 06:17 PM
40th_roadster's Avatar
40th_roadster
Default Help With Bigger Tires
I currently have 255/45-17 (front) and 285/40-17 (rear). I want to put WIDER tires all around. How much wider can I go, and which brand do you recommend?
Old Nov 25, 2001 | 06:19 PM
scorp508's Avatar
scorp508
What size are your rims?
Old Nov 25, 2001 | 08:21 PM
40th_roadster
Default Re: (scorp508)
17" x 8.5" (front)
17" x 9.5" (rear)
Old Nov 25, 2001 | 08:25 PM
95autoLT1's Avatar
95autoLT1
Default Re: Help With Bigger Tires (40th_roadster)
You could go 275/45/17 up front and 295/40/17 in the rear.. I'm not sure if 315's will fit on the 9.5 rims..My brother has 315's on his car but has the 17x11" rims so 295 would be my guess for the rear :cheers: :cheers:
Old Nov 25, 2001 | 09:41 PM
out2run's Avatar
out2run
Default Re: Help With Bigger Tires (95autoLT1)
Don't go with 315's tires on the rear 9.5" rims. They will fit but looks really strange and handling is probably hurt.
Old Nov 25, 2001 | 09:43 PM
carter200's Avatar
carter200
They don't make a 295 so you're biggest is the either the 275 or 285. The reason I say either is that some manufacturers make a 275 that is wider than the 285 of others. Great tires are the Sumitomo HTRZ's and they are wider than most in the 275 compared to others 285's. :yesnod: 295's :lol: They don't make em!!!
Old Nov 25, 2001 | 09:53 PM
Corvette Kid 92's Avatar
Corvette Kid 92
Default Re: Help With Bigger Tires (carter200)
get new rims :yesnod:
Old Nov 25, 2001 | 09:55 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Help With Bigger Tires (Corvette Kid 92)
If you get new rims, look at my signature for sizes. These are the GS sizes. They perform as good as they look. I would also recommend the Michelin Rubber. Blows away GY and was better than my Bridgestone RE-71s.
92TripleBlack
To Help With Bigger Tires
