ramps
Old Dec 20, 2007 | 11:52 PM
arizonaames269's Avatar
arizonaames269
Default ramps
What ramps are you guys using on your C4s? I have looked at many on the web for sport cars but do not know if any will work...jim
Old Dec 21, 2007 | 12:09 AM
arizonaames269
Just did a search and came up with this....
http://www.mustangworld.com/ourpics/...amps/index.htm
Old Dec 21, 2007 | 12:33 AM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
I have these, but the spoiler has to come off because they dont clear.
but I am going to make some like you put in the link so I don't have to remove the spoiler to use.....
Old Dec 21, 2007 | 12:38 AM
qws's Avatar
qws
I use the Rhino Ramps. Since my front is very low I use a 5 ft 2 x4 just before them so I drive up on that first then right up the ramp
Old Dec 21, 2007 | 12:40 AM
arizonaames269
They do seem like a good idea, Cinneman, but I see that they are only 4 high which translates to about 7 inches high. Perhaps by adding another piece of wood, one can achieve almost 9 inches high.....maybe. They will be heavy to move around, however.
Old Dec 21, 2007 | 12:43 AM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
Well they are plastic, but "QWS"'s wood idea might just be the solution.
Old Dec 21, 2007 | 12:46 AM
Dads90's Avatar
Dads90
My spoiler rubs as I roll up but not enough to move the ramp and I drive right up. It's a Rhino ramp.
Old Dec 21, 2007 | 12:54 AM
RRT vette's Avatar
RRT vette
I have a 2 sets of the heavier duty Rhino ramps. They work great for changing oil and what not. I usually put a brick infront of the front tires before driving onto the ramps. Like stated, the spoiler will rub if you don't use something to drive up on first. You can also drive on them backwards if you need clearance in the rear.
I can drive up on the back tires and jack the front up and place the other set under the front. I trust them enough to get most of my body under the car.
Old Dec 21, 2007 | 04:41 AM
SK.LT1's Avatar
SK.LT1
I use the Race ramps available from any of the corvette accesory companies {Ecklers,Mid America,Corvette Central,etc.}They work very well and I no longer need to use planks for clearance.
Old Dec 21, 2007 | 06:07 AM
RRT vette's Avatar
RRT vette
http://forums.corvetteforum.com/show....php?t=1513991
Old Dec 21, 2007 | 06:29 AM
arizonaames269
Thanks Guys for the input. Looks like it is a good idea to use the Rhino ramps for most jobs where portable is a factor and to make and have available the wood ones for a project that might require more time under the car with a run up outside the garage. Seems the wood ones would be safer as well......jim
Old Dec 21, 2007 | 06:44 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Rhinos.
Old Dec 21, 2007 | 12:28 PM
runner140*'s Avatar
runner140*
A quick fix to Rhino ramps sliding is... first, throw down an old, rubber, floor mat.
To ramps
