Dex-Cool: Act 7
Some cars had considerable trouble that was traced to air leaks - mostly caused by the pressure cap.
Joint GM and Texaco Report:
"GM’s Jay Dankovich and Equilon Enterprises’ (Texaco) Stede Granger directed a 2-year study of thousands of DEX-COOL cooled vehicles. Armed with the results, they really didn’t have anything bad to say about the coolant. In fact, they strongly defended the product’s reputation. What they revealed to the audience is that specific models of GM vehicles have specific cooling system contamination problems. And essentially, that DEX-COOL is not the culprit!
What was said at the presentation? Besides the video, Jay and Stede included their personal observations about the study. At the end, they fielded several questions from the audience. Here’s a recap of their entire presentation:
1. Keep the cooling system filled. In fact, fill the reservoir bottle to “Hot” level when the system is cold. Problems arise when a system’s coolant level is not maintained. (Fleet vehicles receiving regular maintenance, and with reservoirs kept slightly above normal, do not show signs of contamination. This even applies to the specific “problem” vehicles.)
2. The coolant problems found in this survey were caused by system contamination, and not due to the breakdown of DEX-COOL.
3. Check and keep the pressure cap clean and functioning. A contaminated and/or malfunctioning cap causes low coolant levels, which in turn causes overheating and a greater loss of coolant: the notorious vicious cycle. No matter what the vehicle, if the cooling system acts suspiciously, test the pressure cap.
4. On the ST vehicle models mentioned in the GM DEX-COOL video, you “must” replace all suspect radiator caps, especially those with a Drop-Center design, with a Stant Model 10230 or 11230 (Spring-Center type). (Just do it.)
5. Make sure that the coolant is at a 50-50 mix. Often, the flush water was not being removed from the engine block. Consequently, when a 50-50 mix is added to the system the resultant mixture could approach 30-70. Like any fluid that has been diluted beyond its recommended levels, the lowered level of inhibitors will not be able to protect the coolant system effectively. Low levels of inhibitors can cause pitting on aluminum surfaces and general corrosion of cooling system metals.
6. A safe method of achieving a true 50-50 mix is to first determine the actual capacity of the system (use the owner’s manual). Then add 50% of “that” amount of undiluted DEX-COOL (or any coolant), and top it off with water.
7. Mixing a “green” coolant with DEX-COOL reduces the batch’s change interval to 2 years or 30,000 miles, but will otherwise cause no damage to the engine. In order to change back to DEX-COOL however, the cooling system must first be thoroughly drained and flushed.
8. Bacteria cannot live in a hot, Ethylene Glycol environment and is therefore not a threat to DEX-COOL.
9. While there have been intake gasket failures on CK Series, V8 powered vehicles for various reasons, DEX-COOL has never been found as a cause.
10. Use a refractometer to check the condition of DEX-COOL. Its inhibitor package is strong enough that if the batch still provides proper freeze protection, it is probably still providing proper corrosion protection as well.
11. DEX-COOL can handle the minerals in hard water better than silicated conventional chemistry coolants. Drinkable water is suitable for top off.
12. In ST Blazer applications where the radiator cap is mounted at an angle to the ground, the vehicle is more susceptible to radiator cap contamination and its related problems. The Stant 10230 is a wise choice for these vehicles."
I am only one of the thousands of people supporting the class action legal effort against Texaco and GM and we've heard this spin several times in the past.
Do a GOOGLE search on "Dexcool class action suit" or visit this link and get the the other side of the story:
http://www.consumeraffairs.com/autom...m_dexcool.html
ALSO, You should seriously consider replacing the DEXCOOL in your GM cars with another brand or have it flushed out of your car every 12 months or 18K miles.
Dexcool is
1. 2001 Monte Carlo (115,000 miles)
2. 2000 Silverado (96,000 miles)
3. 1996 Corvette (82,000 miles)
Not a single issue with any of them. No sludge in coolant recovery tank.
Yes, I have heard about the class action lawsuite ZRWON pointed out. I agree there are thousands of people with issues. But on the other hand there are literally millions of these cars on the road with no issues too.
So, as with most everything else Your Mileage May Vary.
Matthew
Oh, btw, my car was properly maintained, so to me it wasn't an issue of neglect.
2001 Grand Am problems at 30K
2003 GMC 2500HD problems at 4K
2002 Z06 no problem but will be changed shortly
Just do not trust the stuff, I now run Prestone yellow.
