Hi folks , my 1990 L98 reads 40 psi when cold at idle, 10-15 psi hot at idle, about 30-40 while driving using 5w-30 dyno oil...I live in s.Florida. Is this normal?
I can hear the valvetrain but for some reason all the c4's I've heard seem about the same. Kinda noisy. BTW would you switch to Synthetic 10-30?? Thanks
I think as long as its running good with those pressures you will be ok. Maybe take your valve covers off and ajust lifters and check for oil at the rockers. I have had early SBC's that ran fine with low oil pressure. At this point I would stick with the dino.
