Hi all I got this new shifter **** off of eBay I think it looks really cool. It went on pretty easy. And it works real well It is spring loaded and you push the whole thing done to shift into gear. I had to file the lever on the top a tiny bit other then that it works nice..
Looks good Now get the shop vac out and get it cleaned up looks like you have some filings to clean up.
Thanks it was $20 on eBay and its made to work on a stick or automatic its spring loaded with a slide collar I like to have different things non stock and the mess is ashes..
I do need to clean it up.
