Violent Bucking '86 C4 problem
Old Dec 30, 2007 | 08:06 PM
armand49's Avatar
armand49
5th Gear
Default Violent Bucking '86 C4 problem
Man, this was a wild experience. Have an '86 C4. Only mods were removal of air pump and modifying MAF. has been running great for years. I was on a 300 mile run when half way though on a flat road going about 62 mph the car bucked so violently that my body was being whipped back and forth. I noticed that all the power to the instruments went dead. Since I was in heavy traffic, I flored it. It contined to buck, but eventually caught and i was able to get off the road. All was back to normal til i needed to punch the trottle. Then it started bucking again. Now, I can cause the bucking by flooring it hard in any gear, but it won't happen with slow acceleration.
i checked for vacuum leaks, MAF seal, ground wires, etc.
Any ideas guys....this raised hell with the car. it banged the rear end everytime the engine caught and then shut down, just to bang again. Not a cool feeling.
Old Dec 30, 2007 | 09:24 PM
GIMMESOME's Avatar
GIMMESOME
The symtoms you indicate lean toward fuel delievery,other than your gages going dead.That seems like an electrical problem.Sounds like the car is just shutting down intermittently,or going into a limp home mode.But in limp home,your insturments shouldn't go dead.You checked the grounds,it must be on the + side.That's all I can think of.This can be frustrating.Check all battery positive connections,good luck.
Old Dec 30, 2007 | 10:00 PM
armand49's Avatar
armand49
5th Gear
Default bucking
Thanks...will take any all advice. Have a happy new year.
Old Dec 30, 2007 | 10:27 PM
Bob CTS's Avatar
Bob CTS
Check the idle air control valve, smptoms similiar to my 86. You can clean them and reassemble make sure the pintle is restored to the correct dimension upon assembly. They can get dirty.
Old Dec 30, 2007 | 10:28 PM
armand49's Avatar
armand49
5th Gear
Default 86 bucking
Will do....thanks!
Old Dec 30, 2007 | 10:58 PM
Johns87's Avatar
Johns87
Hello,
If you don't find it, would you define 'bucking'. I don't know what you mean exactly about bucking. I have an idea of what is wrong but want to know exactly what is going on.
Take Care and Be Safe, -John
Old Dec 31, 2007 | 12:20 AM
gabezC4's Avatar
gabezC4
Default Fuel Delivery
Sounds like a fuel pump or fuel filter issue when you say is buckles when you punch it as opposed to a slow and steady acceleration.
Old Dec 31, 2007 | 12:24 AM
cv67's Avatar
cv67
St. Jude Donor '05
Also check the red wire going into the distributor cap to see if its loose.
Old Dec 31, 2007 | 12:58 AM
Siveck's Avatar
Siveck
Temporarily disable the EGR by pulling the vacuum line. See if it still has the issue. Make sure to plug the line so there is no leak.
Old Dec 31, 2007 | 02:00 AM
Joescrvette's Avatar
Joescrvette
Also check the TPS (Throttle Positioning Senser) they do strange things when they are going out..good luck to you.
Old Dec 31, 2007 | 02:15 AM
Bubba91's Avatar
Bubba91
mine did something similar and it was the map sensor.
Old Dec 31, 2007 | 12:12 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default bucking bronco
check the connectors on the ECM. check the grounds on the dash and lastly, it really sounds like a bad ignition switch , turning the engine on and off.
Old Dec 31, 2007 | 01:47 PM
Chatman's Avatar
Chatman
The power to the instruments went dead, right? How could it not be electrical?
To Violent Bucking '86 C4 problem
