steering column
Old Dec 30, 2007 | 09:05 PM
vincev's Avatar
vincev
Default steering column
hi, i might picked up a fairly nice 90 convert. the only thing that concerns me is that the steering column has a lot of movement in it.it steers fine but the column has a lot of play.the owner said that many of the c4's have this because people pull on the steering wheel to help themselves out of the car.anyone have any thoughts if this is common?by the way."hi,i just found this forum.
Old Dec 30, 2007 | 09:55 PM
ZRWON's Avatar
ZRWON
The owner is partially correct but IMHO the real cause of the wobbly steering column is a poorly designed tilt link assembly with weak metal used for the left and right tilt column pivot pins. This is not unique to C4s but to ALL GM products from that era with adjustable steering columns.
You'll get a good understanding of the problem and complexity of repair at this site http://domesticmisfits.net/forums/viewtopic.php?t=124
It's a labor intense and complex job to replace a couple inexpensive parts...not for the amature esp on cars with air bags. I've heard estimates of >$500 to repair. I drove my '84 ElCamino over 50K miles after the steering column started the wobbly. Nothing happened but I sure worried. Don't know of any actually breaking or any injuries resulting.
Old Dec 30, 2007 | 10:34 PM
vincev's Avatar
vincev
thanks for the info.was worried about the safety aspect.
Old Dec 31, 2007 | 09:01 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Hey, You mention the pins being a weak metal. Can I make ones of a better metal? Or put a bushing in there with a tougher metal?
Old Jan 1, 2008 | 11:51 AM
ZRWON's Avatar
ZRWON
Never thought about that...guess it could be done with a lathe. You can buy bolts with various degrees of hardness. It's almost the shape of a bullet rounded a bit on the end that enters the tilt pivot
with a larger diameter near the other end and a small lip on the outer end.
The tough part is getting the tilt linkage out to where you can access the pins. Replacing it with a custom pin probably would not be cost effective. The stock pin if replaced with another stock pin will last another 70-90K miles and is not expensive. It's just a shame that when GM made this assembly in the eighties they could have used a stronger pin so it'd last for a couple hundred thousand miles...but then few auto manufacturers want to make cars that would last that long
It's not only used by some just to get in and out of their cars but in the case of the C4 the pin gets a lot of extreme pressure on it in racing etc. How'd you like to have one break in an race when you are cruising along at ~140mph?
Old Jan 1, 2008 | 03:18 PM
steve40th's Avatar
steve40th
Thanks. I am going to tackle mine in the next couple days.
Old Jan 1, 2008 | 03:54 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Before you start playing around with the steering wheel make sure you pull the fuse to disable the air bag. You don't want that thing going off.
Old Jan 1, 2008 | 04:19 PM
steve40th's Avatar
steve40th
I will do the fuse and the battery.Thanks. FSM is my friend
Old Jan 1, 2008 | 05:36 PM
scranage's Avatar
scranage
I've only torn one column apart, but the tilt pivot pins were steel, and in fine shape. The housing they go into was potmetal. Potmetal is way too soft and easily deforms allowing the pins to draw out of the holes they are pressed into.
Old Jan 1, 2008 | 05:56 PM
steve40th's Avatar
steve40th
Should I put bushings in the housing? I guess I will see when I get in there tomorrow. I dont want to get a housing,a s they are 350!
Of course a used column is probably cheaper.
Old Jan 2, 2008 | 02:54 AM
scranage's Avatar
scranage
Getting a new housing from GM is unlikey, most of these parts are discontinued. Try re-seating the pins first and see if that holds. A complete column tear down is very tedious even if you can locate replacement parts.
BTW, a used column is likely to arrive ruined unless you get one from someone who knows what they are doing. The column is very delicate once removed from the car. The lower shaft has thin plastic shear pins that will break from even a light tap on the bottom during removal or shipping. Repairing that requires yet another expensive and/or discontinued part.
Old Jan 2, 2008 | 07:17 AM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Here is the part that needs to be replaced, might want to also include a set of bearings as well. http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Hope this helps.
Old Jan 2, 2008 | 09:46 AM
scranage's Avatar
scranage
I wish I'd known they still had some of those last winter when my column was torn apart on the kitchen counter
Anyway, that's a great price on a hard to find part - I ordered one to put on the shelf in case my pins work loose again
Old Jan 2, 2008 | 01:39 PM
steve40th's Avatar
steve40th
Hope this helps.
Nice. Now why does it only go to 92? I have noticed threw the years 93 have their own specific stuff.
Old Jan 2, 2008 | 06:58 PM
c4sforever's Avatar
c4sforever
St. Jude Donor '06
Good question, I was hoping that the link I posted covered th OP's year. Never thought to look into other years, I did however get one from them for my '84
To steering column
