Braking options
Ask for Chris. He's got the best prices around and gives CF members a good deal.
If you go with the J55 upgrade you can use your original wheels, if you're going to go with C5 brakes you'll have to get either ZR1 (A-molds) or C5 wheels. The C4 saw blades won't clear the C5 calipers. Also, you don't need to change the rears, just replace the pads.
Jeff
The standard brakes on a C4 and the J55 option are the same for the rears. J55 is fronts only, the rotors are 13" diameter and about 1" thick (vs 12" x 7/8" standard). C5 front rotors are 13" x 1 1/4", the rears are 12' x 1 1/8" (I think, I'd have to measure them). In any event the C5 rotors are too thick to use with C4 calipers.
Additionally, the C5 and C4 parking brakes are totally different. If you use a C5 rear caliper on a C4 you will not have a parking brake. The difference in rear braking power of the C4 and C5 is minimal so most C4 owners don't even attempt to convert the rear brakes.
Finally, the calipers for the base C5 brakes and the Z06 were the same, the only difference is the color: red = Z06, black = base.
If you search Superior Chevrolet's web site they've posted a parts list for the C4 to C5 brake conversion. You'll note that it only addresses the fronts. As I posted earlier most owners who do the conversion just paint the rear calipers to match the fronts. https://www.superchevyperformance.co...les.asp?ID=124
One last thing, C5 rotors are heavy and are usually not worth shipping. Most good auto parts stores, like NAPA and Chevy dealers stock them.
