While working on the g/f's dads car I accidentaly popped the power lock fuse. I don't see it in the passanger side fuse pannel. Can anybody be so kind and point me in the right direction? I'm not sure of the exact year, but it is an LT1 car.
If I remember correctly on my 92 when I had the same fuse issue, it was on the auxillary fuse block which is located on the footwell panel, now I just cannot remember if it was on the passenger side or driver side!
I ended up finding the fuse block in the passanger side lower dash. Why GM would hide a fuse block with 4 fuses under the passanger side dash, I have no idea.
Sorry I could not help you out more! I was in just as much disbelief and bedazzlement when I found it too!
Good luck!
