Which Way Do They Go?
Jan 9, 2008 | 04:41 PM
I purchased an 89 coupe last April and for a winter project, I plan on refinishing the wheels. The clearcoat is pretty shabby but the wheels are in good shape. My front wheels are facing in a different direct than the back ones. I have looked at pictures of other 89's and it looks like there is no standard direction for the wheels? I would think all 4 wheels should be going in the same direction. I'm leaning toward the wheels as they are on the front. Any opinions? I know I can switch them if needed.
Jan 9, 2008 | 04:46 PM
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
your back wheels are correct
Jan 9, 2008 | 04:57 PM
Thanks, I have seen pictures with them both ways.
Jan 9, 2008 | 04:59 PM
i believe you will also find the side molded in the inside of the rim as well
least ways it is on 87's
Jan 9, 2008 | 06:01 PM
I will check that when I get them cleaned up. I did a quick cleanup on them when I got the car but they are still pretty greasy etc. on the inside.
Jan 9, 2008 | 08:38 PM
Cruise-In X Veteran
St. Jude Donor '09
Back wheels are correct, actually helps cool the brakes. Check the rotation arrows on the tires too.
Jan 9, 2008 | 09:45 PM
Leave the wheels alone, it'll confuse people
Jan 9, 2008 | 09:53 PM
Quote:
Originally Posted by
bizaro
88/89 wheels draw air into brakes
later sawblades are reversed.
Jan 10, 2008 | 01:09 PM
bizaro
