New Guy!!
Old Jan 10, 2008 | 02:33 PM
C-Note's Avatar
C-Note
Navigator
Default New Guy!!
Just stopped by to introduce myself.
Just bought my first Corvette, a 1992 LT1 6 speed coupe.
I have been a muscle car owner for many years and have had a Dodge Viper for about two years now.
Just wondering if there is any good advice you guys/gals could give to a first time C4 owner, am I in for any surprises?
Thanks in advance.
Old Jan 10, 2008 | 02:37 PM
CSS996's Avatar
CSS996
Surprises?
Like how much fun a C4 is for almost no money? That was a pretty big surprise for me!
Just read and learn. You'll get lots of info. here. And some of it will be good.
Old Jan 10, 2008 | 02:38 PM
94z07fx3's Avatar
94z07fx3
Welcome aboard!
"any advice?"
Yes!
Never ever ever ever ever wash the engine compartment.
Buy the real FSM not a Chilton or Haynes.
Clean and lube the release cables for your hood latches with lithium grease.
Re-install the top on level ground.
Keep the trash out of your radiator.
Old Jan 10, 2008 | 02:41 PM
C-Note's Avatar
C-Note
Navigator
Thanks!!
Thats just the kind of stuff I am looking for!!
Old Jan 10, 2008 | 03:11 PM
StealthLT4's Avatar
StealthLT4
That pretty much sums it up! Be sure to get the red-cover FSM and not white; the white ones are preliminary editions and, frankly, suck.
One last thing; DRIVE IT! These are great cars. Welcome to the forum.
Old Jan 10, 2008 | 03:17 PM
bd2626's Avatar
bd2626
Welcome to the madness
Drive the car and enjoy it!
Old Jan 10, 2008 | 04:43 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
Welcome to the CF! You picked a great year and tranny (just like mine!)!
The reason for not washing the engine compartment is to not get the opti-spark wet. It is in the lower front passenger side engine compartment. Watch for the water pump seeping, as it is right in back of the opti. If you have to change the water pump, you might as well plan to do the opti also as most people get roughly 70-100K per opti.
92 is the first year for the reverse flow LT1 engine (as you probably already know). They are a hell of a lot of fun and still get 28+mpg on the highway which continues to amaze me!
Watch for lumbar pump failures and power seat track failures if yours is so equipped.
Learn how to pull codes so you can see what the computer is telling you what is wrong. If you have the slective ride control (FX3) option, learn who Captain Z CNC is, he rebuilds the plastic actuators with aluminum at about 1/3 of the price of a new actuator!
Post up some pics when you can because we all like to check out each others rides!
Tim
Old Jan 10, 2008 | 05:15 PM
C-Note's Avatar
C-Note
Navigator
Thanks for the info Tim,
I will post some picks soon, right now the car is up on stands in the garage with the tranny torn out.
I bought the car with a bad clutch, the part of the throw out bearing that the pull arm pulls on was busted off.
I got a smokin deal on the car!!
When I get it put together I will put some pics up!!
Next question, do I put an aluminum flywheel in now that I have the car apart?
Any thoughts?
Old Jan 10, 2008 | 05:35 PM
Iron Chef's Avatar
Iron Chef
St. Jude Donor '06-'07-'08-'09
CI 8-9-10 Veteran
Welcome aboard
Old Jan 10, 2008 | 06:40 PM
wmupaprmkr's Avatar
wmupaprmkr
Any thoughts?
You are welcome, and how hard are you going to run her (wrt the aluminum flywheel question) and are the flywheel teeth worn?
Old Jan 10, 2008 | 06:43 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Definately:
1st Welcome to the money pit,,,, drive, and enjoy..
2nd: Helms FSM (only)
3rd: Learn how to use the SEARCH function, Archive posts, read, read, read and enjoy... 98% of your new questions have already been answered 100+ times and your see all the options available
4th: Have Fun
Old Jan 10, 2008 | 08:36 PM
aminnich's Avatar
aminnich
Any thoughts?
Lot of debate about the al flywheel and seems it is more prone to noise and vibration, but good for a 'track' car, not so good for a stock street car.
another tip or two:
learn how to use the bleeder screws to get trapped air out of the engine if you have a low coolant situation.
Factory fan setting is on at 227*F, expect it to get hot in city traffic and over 240*F is the danger point.
Check area between condenser and radiator for debris on a regular basis and suck the crud out when you see it (small opening on the shroud, pass side you can peer into the area and a shop vac home made wand will help suck out any junk).
Use dialectric grease to wipe down all the weatherstripping, rub it in lightly and wipe of all excess.
Check and change all fluids, belt, hoses unless you have a maintenance history.
Keep the ASR on until you get used to it.
Enjoy!!!!!!
Old Jan 10, 2008 | 08:44 PM
C-Note's Avatar
C-Note
Navigator
Thanks for all the great advice!!
To New Guy!!
