Delayed starting
Old Jan 10, 2008 | 08:52 PM
Yellow92LT1's Avatar
Yellow92LT1
Default Delayed starting
I have been noticing a problem as it getting colder, and the car sits more. When I turn the key I get a delayed start. The car starts fine, but only after I hold the key for 3 seconds or so. (I get no cranking or nothing for 2-3 seconds) Then she fires right up. This only happens when the car sits for a week or two, other than that it fires right up. I would swear the car had no electrical at all....then it fires right up!
Low battery? Anyone have the same issue?
Old Jan 10, 2008 | 08:58 PM
94z07fx3's Avatar
94z07fx3
...nvm I misread.
Old Jan 10, 2008 | 09:45 PM
Demonic85's Avatar
Demonic85
All cars do that when let them sit for a while like that. Mine starts up like that everytime now no matter how often I drive it. Its probably cause I have a AFPR and there is a very quick leak down in pressure when I shut the car off. My guess would be that since you let the car sit for a week or so that theres not fuel sitting in the injectors ready to go. Or it could be a drop in voltage that would make it take longer to crank (weak battery).
Old Jan 10, 2008 | 09:55 PM
Yellow92LT1
It is a strange problem. Turn the key over.....absolutely nothing, continue to hold in the starting position, after a few seconds the starter cranks. It is a true delay.....?
Old Jan 11, 2008 | 12:14 AM
RRT vette's Avatar
RRT vette
This doesn't sound like a weak battery. Sounds like an electrical glitch. Have you tried a different key?
Old Jan 11, 2008 | 12:18 AM
Siveck's Avatar
Siveck
Ignition switch out of adjustment? Maybe the switch on the column has moved a little?
To Delayed starting
