headlights
Old Jan 12, 2008 | 07:49 AM
golfpro's Avatar
golfpro
7th Gear
Default headlights
I am in the process of full restoring a alpine white 96, which is almost done. I am having some problems with the headlights. When the lights open or close the motor keeps running for a few seconds and the lights make a cliking noice. Can anyone help? Thanks
Old Jan 12, 2008 | 09:04 AM
C4DERF's Avatar
C4DERF
Replace the bushings in the headlight motor gear box. Parts are inexpensive from the major C4 parts stores and it takes a little time to do both headlights (suggested do both at same time). Check this link for assistance. http://www.corvettemagazine.com/2002...hts/light1.asp
Old Jan 12, 2008 | 10:36 AM
1fasta's Avatar
1fasta
Cruising
i rebuilt mine for the same reason. 89 C4. went to a corvette restoration place in town to pick up the parts(3 nylon bushings per side) and paid $30. found the same parts on ebay at a later date for $5. oh well, already done. job will only take you about 2-3 hrs if your a novice at it as i was. first side is learning curve, second one is GRAVY good luck
Old Jan 12, 2008 | 11:09 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Thanks for the reference. I am going to store it for future reference.
Old Jan 12, 2008 | 11:10 AM
KBoltz's Avatar
KBoltz
Mine just started to do the exact same thing. I just ordered the bushings and bronze gears from Corvette Central - total for the set with shipping was $148.75.
The two bronze gears was the most expensive - they were $59.95 each. I decided since I have to take it apart anyway, might as well fix it right. The two sets of bushings cost $5.95. Shipping was 16.95 - seems really high, but I have never been disappointed with anything I have had to purchase from CC.
Old Jan 12, 2008 | 11:30 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Bushings
Old Jan 13, 2008 | 01:02 PM
oaklands's Avatar
oaklands
If you go the nylon bushing way, you can go to home depot and find them for about $2.95 for a pack of 2.
Old Jan 13, 2008 | 07:42 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Just bought the parts at car show, tomorrow project!
To headlights
