Has anyone switched over from dex cool to the green coolant? Did you have any problems after? Anything to keep in mind besides giving it a good thorough flush? Is there any benefit in lower engine operating temperature if you switch?
With older "conventional" antifreeze products, the recommended replacement interval is usually every two years or 30,000 miles. The same recommendation applies to extended-life coolants that have been contaminated with ordinary coolant. If somebody uses ordinary coolant to top off a system that is filled with extended-life coolant, the additive packages can interact and reduce the service life to that of regular coolant. The trouble is, you can't always tell if extended-life coolant has been contaminated with regular coolant. Most long-life products are dyed orange while most ordinary coolant is dyed green or yellow. But color shifts can occur naturally as a coolant ages, and it takes a lot of cross-contamination to produce a noticeable color shift with some products.
OAT corrosion inhibitors provide excellent long-term protection for aluminum and cast iron, but may not be the best choice for older cooling systems that have copper/brass radiators and heater cores. It depends on the formula. One ACDelco spokesman said they do not recommend Dex-Cool for older vehicles with all-iron engines and copper/brass radiators.
There are two primary types of coolants available on the market today. The first is traditional, green-colored antifreeze, which can be used in any car. The second is a newer, long-life coolant, which comes in a variety of colors. It should only be used in recent-model cars because it may damage some of the engine gaskets in older cars. If you're not sure whether your car uses the new or old-style antifreeze, check with your manufacturer.
Several years ago, early formulations of Dexcool would form sludge after mixing with air, clogging cast-iron cooling passages and generally wrecking havoc on engines. GM seems to have fixed the problem, but why take a chance? Keep an eye on it.
This seems to indicate that dex cool may not be the best choice for the 12 year or older LT1 cast iron engines, despite GM putting it in later C4s when they were new. The main advantage seems to be longevity but with the small number of miles I drive every year there is no way I'm getting 50K or 100K miles between coolant changes. I have some sludge forming in mine that is evident in the overflow tank when the car has been sitting for a number of days and I just can't see a single good reason for staying with the dex cool.
I also have a 96 and about a year ago got the notion that I should drain out the dex-coolant and put in the green stuff. I found a shop that would do the change out and I watched as they did the work to be sure they completely flushed out the dex cool and put in the green stuff. Within three months I had a coolant leak, and discovered a hole in the radiator because of the green stuff. I had to replace the radiator, replace the hoses, have the block flushed completely, and put the dex-cool back in. A costly mistake on my part! I will always run the dex-cool after this experience.
more than likely the rad. was going to leak. The rad. is 12 years old.My 95 had dexcool in it. My vette mechanic (only works on vettes)suggested that I change the antifreeze which I did more than 2 years ago because of some issues he had with other vettes.I think the key is changing the dexcool every year to avoid problems.
I've read the writeups on the class action lawsuit and the claims of sludge in the coolant, some people say it eats gaskets and aluminum parts. Other sources say it is fine. One source says to keep using it if your vehicle came equipped with it. A vette shop I called told me they change all coolant in the corvettes they service to the green stuff. There doesn't seem to be a consensus. I think I'm just going to stay with it and flush and replace it every year.
i have 96 with 16000 miles which i purchased 2 years ago with 8000 miles ,i dont think it was ever changed, maybe its time do you have to remove the freeze out plugs or can i just drain what i can and replace
