do these things actually work
Old Jan 16, 2008 | 10:54 PM
ZfidyONE-84's Avatar
ZfidyONE-84
Default do these things actually work
looking thru the corvette catalog, and i came up upon the air foils that go on the throttle body, and the smooth air intake tube for the tuned port injection... and do these things actually work, or are they just another gimmick?
Old Jan 16, 2008 | 11:04 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Not that I have ever heard, but I have read posts about them breaking apart and ending up destroying valves and pistons. Search!
Old Jan 16, 2008 | 11:08 PM
ynk1121's Avatar
ynk1121
no performance increase and I've seen plenty of carnage pictures from parts of it going down the intake.
Old Jan 16, 2008 | 11:13 PM
StealthLT4's Avatar
StealthLT4
waste of money. no performance gain. The screws that hold it in have a history of coming undone and being sucked into the engine... = not goodness.
Old Jan 16, 2008 | 11:19 PM
WickedVetteLT4's Avatar
WickedVetteLT4
No Dice!
Old Jan 16, 2008 | 11:39 PM
5speedC4's Avatar
5speedC4
I hadn't heard of any of them coming apart. My corvette came with one on it when I bought it.
It sounds like I might take it off.
Funny TPIS makes them sound like the best thing since sliced bread on their webb site.
I left mine on my vette, because I figured it couldn't hurt anything.
Old Jan 16, 2008 | 11:40 PM
vader86's Avatar
vader86
Have heard of them coming loose and getting sucked into the intake.
However, as far as the catalogs go, my recommendation is to pick yourself out a hat, maybe a shirt, and throw the thing in the trash.
Old Jan 16, 2008 | 11:46 PM
5speedC4's Avatar
5speedC4
I guess the smart thing to do, would be to take it off and throw it away.
Old Jan 16, 2008 | 11:48 PM
WickedVetteLT4
Lol. I would agree with that.
Old Jan 17, 2008 | 12:54 AM
psychodiagnostik's Avatar
psychodiagnostik
I those things are in one of the faqs listed under "mods that don't work". I'm ashamed to say that I had one on my LT1 Z28 about 14 years ago when I didn't know better... ZERO performance gains.
I can't believe those things are still in the catalogs.
Old Jan 17, 2008 | 12:58 AM
Harryscarlot's Avatar
Harryscarlot
put them in the trash next to those " Tornados"
Old Jan 17, 2008 | 01:01 AM
trulytex's Avatar
trulytex
There was one in mine when I bought my Vette 2 years ago. The mechanic at the Chevrolet Dealership removed it a few weeks ago when my heads were redone on my car.
Old Jan 17, 2008 | 03:31 AM
85L98-84L83's Avatar
85L98-84L83
I have one if they don't do anything why do all the new replacement ones have them such as BBK, etc....?
They might not do anything but the 101 things to do to your C4 book had it in there, so why not?
Old Jan 17, 2008 | 10:37 AM
NEVRL8T's Avatar
NEVRL8T
http://forums.corvetteforum.com/show...=air+foil+bolt
Old Jan 17, 2008 | 10:50 AM
ineVETTEable's Avatar
ineVETTEable
Snake oil
Old Jan 17, 2008 | 11:41 AM
VETTEHIGH's Avatar
VETTEHIGH
Originally Posted by TheAngelOfDeath
ALL I CAN FOREVER SAY
Old Jan 17, 2008 | 12:17 PM
5speedC4's Avatar
5speedC4
I'm taking mine off. I am in the middle of installing a miniram, so when I put it back together I will make sure it does not have the airfoil.
Was there anything in place of the air foil from the factory?
What did the air foil screw into?
Did they have to drill a hole for the screw, or was the screw hole already there?
I am just wondering how the air foil was attached if there was nothing there to begin with.
scary scary scary
At any rate, I will take mine off, and leave the screw hole with nothing in it.
Thanks for the information.
To do these things actually work
Old Jan 17, 2008 | 01:33 PM
Greg Gore's Avatar
Greg Gore
I would think if you tested it on a stock engine back to back on a carefully calibrated dyno you would observe no change one way or the other. The theory behind the design is good because airflow likes a radiused entry. The problem is a stock engine flows so little air that the radiused entry would not come into play and as others have stated it would most likely fall off and get sucked into the engine unless you were careful about how you installed it, Loctite, good grade of screws torqued, etc. I wouldn't bother. Get big gains by putting a good set of heads on the engine instead.
Old Jan 17, 2008 | 01:38 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Old Jan 17, 2008 | 01:44 PM
TA's Avatar
TA
Originally Posted by ineVETTEable
Snake oil
