From: Wichita, KS, USA Vote John McCain in 2008 God=Santa Claus 4 adults
LT1 to LT4?
I saw someone in another thread state that it's cheap and easy to convert an LT1 to an LT4. Is this really true? Does the LT4 have the optispark also? Are they the same block and different heads and intake? I know the LT4 has roller rockers and the LT1 doesn't but I'm not sure of the other differences in the engines. Thanks :cheers:
You're better off just doing an aftermarket heads and cam package for a little more money. You'll see bigger HP gains. Take a look at ARE's (link on right side of screen) LT-1 package, that's what I'm going with.
This is also something that i considered doing for a few years...until i got right down to comparing the cost of the LT1 to LT4 conversion. The upgrades are as simpleas BubbleHead says...just change the cam, heads and intake and the change is complete...those are the only differences between the two engines. But for the price...you have other options that'd give you greater payback.
I'm not knocking the LT4 in ANY way! Wish i had one!!! Its a GREAT motor...but for the cost of converting... :confused: ... well...i dunno.
There sure seems to be a common misunderstanding about what the differences are between the LT1 and LT4. There is much more than simply heads, cam, and intake. Take a look at the chart below.
Ericcer is the one linking to the spec tables....but you do bring up an interesting point. If a basic fact such as the recommended fuel are wrong on his tables...what ELSE on the table(s) are incorrect?? ;)
But i STILL like the LT4!!! And STILL wish i had one. :D
I second "the wish I had an LT-4" :yesnod: But after some head work and a new cam, won't matter all that much.
Tain't no thang! Sounds like you've got some "plans" for your LT1! What kind of head work are you going for? and which cam? Also, do you have anything else in mind for "down the road"?
It's going to be a little ways down the road, but I'm stuck between building a stage 1 type 383 or going out and putting stage 3 type top end... looking at either Speed Demon or ARE when the time comes. Figure the above mods, some 3.73 gears, converter and DR's should put me into the 11's.
Both builders are quite a drive for me, but I want someplace that has the knowledge in vettes, where I can drive the car in.. drop it off for 3 or 4 days, then drive it home.
