Replace Front Upper Ball Joint Boots
Old Jan 28, 2008 | 06:08 PM
Black 82's Avatar
Black 82
Default Replace Front Upper Ball Joint Boots
Is it possible to replace the front upper ball joint boots without removing the ball joint?
Old Jan 28, 2008 | 07:09 PM
staugur's Avatar
staugur
A quick answer is no.
Old Jan 28, 2008 | 10:19 PM
vetteblack's Avatar
vetteblack
You could replace it by taking the spindle off, leaving the ball joint in. With all that work though, you may as well replace the joint too. Its a lot of knuckle cutting work!
Old Jan 29, 2008 | 08:03 AM
kalister1's Avatar
kalister1
My lower ball joint boot broke, noticed it when greasing. I could NOT find just the boot, I had to buy the ball joint with the boot. So I put in new ball joints with the new boot.
Old Jan 29, 2008 | 09:16 AM
Black 82's Avatar
Black 82
I've got the spindle and arms seperated. The old boots were ripped so I cut the rubber back to the ball joint. There looks like a thin metal retaining ring holding the boot to the joint, but I can't see how to get it out. The joints are otherwise in good shape and don't really need replacing. Poly replacement boots are available from Energy Suspension.
Old Jan 29, 2008 | 09:30 AM
kalister1's Avatar
kalister1
I order a Ball Joint Boot kit from my local autoparts store, all I got was Tie Rod End boots.
To Replace Front Upper Ball Joint Boots
