So i replaced my fog lights(yay), and while i was under the front of the car i looked up into my radiator to clean out some of the leaves and stuff and ended up seeing this plug, no idea where it came from, never seen it before. here are pics, any ideas.
Here it is circled
and this is a closer view
Wow! You did the working fog light mod. Very Nice! That sure looks just like they said, the underhood light plug. On the drivers side right by the vac ball is a 10A fuse in a weathertight fitting. But the fuse has been either pulled or unplugged as well. I simply wired a little switch on the protected side of the fuse on mine so I can flip them on/off really easily (remember I am lazy).
does your car have electrionc climent control. if not that is the wire for the sensor
It's the (Outside) Temperature Sensor for the Electronic Climate Control. Even though your car didn't come with the ECC, the wire/plug is there. At least that's what I think it is.
It's the Temperature Sensor for the Electronic Climate Control. Even though your car didn't come with the ECC, the wire/plug is there. At least that's what I think it is.
yeah could be this too, i dont have electronic climate control, so it could be. either that or clam shell lights. ill keep the investigation goin, and ill let yall know
its the ECC sensor plug. the underhood lights plugs are right beside the marker light. not down by the fog light.
I've got the same plug on my 94 and I have the standard climate controls. I had looked thru the FSM and didn't find any mention of the plug, Thanks, I'm not going nuts.
