Fuel Pressure Test
The code 16 is not good and usually points to a dying opti spark.
These two are in module 4 (ECM)
Code 16...optispark low resolution (fuel)
Code 42...EST (knock sensor) grounded
This one is in module either module 1 or module 9
Code 74 module 1 (CCM)...LED display open
Code 74 module 9 (ABS/ASR)...Low voltage
The code 16 is a good indication as to why the engine dies. You will need to make sure what module these codes are in (it will tell you what module the code is in on the speedo display). You need a FSM to diagnose each code starting with the lowest code first. Sometimes multiple codes can be the result of one failure or wiring problem and fixing the lowest code first might remove another code. I could help but sold my 92 last month and gave the FSM with it.
http://www.c4guru.com/articles/CCMCodePull.pdf
I cleared the previous codes by disconn. battery. Started the motor with the paperclip still in place and got no codes. After about 5 minutes, engine died. Fuel press. was good.
I removed the clip, started and as usual it dies.
Re-inserted paperclip for the codes and got code H36 on the #4.1 module.
I also got a code on the ASR on the 9.7 module.
It appears my opti is toast.
As to the previous codes I posted, they never came back.
I wonder if I got a code reader to plug in if I could do better??
Suggestions - Comments - Advice ????
Many thanks for the information.
