L98 Headers
Old Feb 3, 2008 | 02:09 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default L98 Headers
I was thinking about putting some headers on my 90 L98. I was thinking they would make the car run cooler and give my a little more HP.
Your thoughts out there about:
#1 - Are there any benefits in the performance,
#2 - Should I go with long or short tube,#
#3 - Should I go with painted or ceramic coated
#4 - Just leave it stock
Old Feb 3, 2008 | 03:09 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
#1 - Yes (but only with quality long tubes)
#2 - See answer to #1
#3 - Ceramic is the way to go, but expensive (You get what you pay for though).
#4 - That's a personal choice. Totally up to you
Old Feb 3, 2008 | 06:03 PM
StealthLT4's Avatar
StealthLT4
Everything he said x2. If you get long-tubes, you will have to get new cats also, since the stock ones are displaced. A set of Random Technology bullets can be had for about $150 each, I think. Or you can go catless (no endorsement from me...im running RT's).
Old Feb 4, 2008 | 10:00 AM
ToniH's Avatar
ToniH
I agree with the others with one side note: you already have stainless short tubes (like all L98's do) from the factory (and they are useless) so like others said long tubes are the way to go.
jwalker: his car is L98, there is one main cat in the middle (precats are gone after the long tubes). He doesn't have get a new cat at all, the stock one will work but a free flow cat would help with the power aspect. Bullet cats will not fit his system until he plans to do a total separate pipes thing to his car.
Old Feb 4, 2008 | 10:43 AM
Square's Avatar
Square
Here is a photo doc of my header install on my 86'. Corvette came with a mini starter starting in 1988, so you can use your factory starter just fine.
http://members.***.net/effergyvette/...r_Install.html
Old Feb 4, 2008 | 11:05 AM
cmcbunch's Avatar
cmcbunch
#1 - Good long tubes=good torque
#2 - All shorties do is create underhood temp rise
#3 - At least get them thermal painted but ceramic is best
#4 - Lol stock, thats funny. Trade vette for minivan
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You can weld on a 3" universal Magnaflow main cat if you want and delete the pre cats. I got mine on eBay for $65. Leaving the main cat will help with resonance as well.
Old Feb 4, 2008 | 11:16 AM
ToniH's Avatar
ToniH
And as its a '90 the main cat will also provide a little back pressure for the Speed/density -system.
Plug and play Magnaflow 3" cat for the car is about $149 at most normal vendors.
Old Feb 6, 2008 | 09:27 PM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Thanks for all your suggestions. However, my throwout bearing just STB so I will have to replace clutch first before I can think again about headers.
Old Feb 7, 2008 | 10:03 AM
mdlfcrss's Avatar
mdlfcrss
It's always something, Len !!!
To L98 Headers
