Mo-Problems
Old Feb 5, 2008 | 11:11 PM
MoFun's Avatar
MoFun
Default Mo-Problems
Alright,i have 2 problems 1st one is i can't get my 93 vette alarm to activate,the remote still opens the hatch,and the passenger side door,but it does not activate when i walk away nor unlock when i approach.2nd thing is i'm getting a code 28 which according to my manual is the Quad driver module #3 circuit, what and where the f#$% is that,it says check the resistance of the air conditionning clutch relay & cooling fan relay coils,and replace if less than 20 ohms,i'll try it,but all suggestions are welcome.
Old Feb 6, 2008 | 11:51 AM
JCD's Avatar
JCD
have you reprogrammed the car to the key fob since replacing the computer? I've seen some weird stuff from my PKE.
I know nothing about the code 28, sorry.
Old Feb 6, 2008 | 01:41 PM
Red Dwarf's Avatar
Red Dwarf
Try holding the door button down on the remote until you hear/see the door locks cycle. It's takes a few swcomds. Sounds like the system has been deactivated. If that works you can select which door (s) open by putting the key in the ignition (donot turn on) & using the door button select which doors you want the PKE to open.
If this info doesn't help you have other issues.
DTC 28 sounds like a transmission problem?????
To Mo-Problems
