New Wheels Installation Question???
Old Feb 6, 2008 | 06:53 AM
beachrover's Avatar
beachrover
Default New Wheels Installation Question???
I started installing my new AFS wheel & tire package last night. I only got the driver's side finished as I ran out of time.
My question is I noticed when I lowered the car that there is a larger "gap" between the top of the tire and the bottom of the wheel well opening than with the original tires & wheels; is that normal, will it "settle" back?
I went back with 17" wheels. The only change I made was to put 9.5" on the front and 11" on the back.
Any responses greatly appreciated!
Old Feb 6, 2008 | 08:41 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yes, it will settle. Anytime you jack the car up, you take weight off the spring. The Corvette transverse leaf spring will keep the car up a little higher when you lower it back down. But as soon as you drive it, it will settle back to normal.
Also, you didn't mention the actual size tire you went with.
So, if you put a smaller diameter tire on there than what you had you will have a little more gap.
Old Feb 6, 2008 | 09:07 AM
Harryscarlot's Avatar
Harryscarlot
I was stooopid and left my car on the hoist with the wheels hanging for about 3 weeks and now I have a bigger gap that has to settle in. it seems as though these springs have a memory effect.
Old Feb 6, 2008 | 09:24 AM
beachrover's Avatar
beachrover
Front Original: 255-45-17 New Tires: 275-40-17
Rear Original: 285-40-17 New Tires: 315-35-17
Old Feb 6, 2008 | 09:40 AM
DaleD's Avatar
DaleD
Not a lot of difference, try this out:
http://www.miata.net/garage/tirecalc.html
Old Feb 6, 2008 | 10:47 AM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Let's see some pics of your new wheels!
Old Feb 6, 2008 | 03:29 PM
beachrover's Avatar
beachrover
I'll have it finished tonight and post tomorrow.
Old Feb 6, 2008 | 04:11 PM
'Shifter's Avatar
'Shifter
NCM Member '09
New wheels is such a cool feeling!
Old Feb 6, 2008 | 06:37 PM
96VetteDriver's Avatar
96VetteDriver
Made the exact same switch a number of years ago - it will settle back down.
Old Feb 15, 2008 | 10:17 AM
beachrover's Avatar
beachrover
I'll try again to post pictures.
To New Wheels Installation Question???
