changing antifreeze
Most mechanics and the antifreeze manufaturers suggest changing the antifreeze every two years even with cast iron blocks.
Phosphate attacks aluminum, The guys with Aluminum blocks learned the hard way when the put regular antifreeze in their block just as they had for 40 years.......Pitted aluminum especially around the heated areas. Head Gasket anyone?
Deionized water is available in Gallon Jugs at the Grocery store. Phosphate free antifreeze is expensive. But so is replacing that Heater core.
I'm gonna start looking in the grocery store for the deionized water....I was using steam distilled in my system.
Dumb Q....who make non-phosphate coolant....any auto part store carries that stuff. I'm using GM 1825-M coolant in my system also but it's getting a bit hard to find...local dealer don't stock it any longer.
Thanks again for the info!
Tom
Some hydrogens unbind, giving you h3O (acidic), and hO (basic) in equilibrium.
Basic stuff binds / deposits ON stuff (like soap, onto your hands). Acidic stuff removes FROM your hands (like skin, from your hands)
Mr wizard out
one thing to remember, there is no such thing as pure water.
When water gets cleaned up real good, it will start dissolving most anything it comes in contact with, including glass and other pipe materials. Of course the amounts are insignificant to 99.9999% of the situations, not enough to notice a degradation in the pipe, but enough to cause a problem when cleaning semiconductors.
For our cars, either distilled or deionized from the grocery store is fine. And depending on where you are, tap water is fine. I think less than a dollar a gallon for distilled water is cheap insurance that I am not putting extra minerals in my cooling system that may cause a problem down the road.
Distilled water is an evaporative process that leaves contaminants behind. Not as pure as de-ionized, but close.
Anyway, by using a 50/50 solution of anti-freeze, any corrosiveness is neutralized and there will be no deposition of impurities.
Just thought I'd bring this to the front. I've got 35 years as an industrial chemist. Experts in any field are what forums are worth.
So to throw out my Quals I have a Degree in Physics and I worked for two years on a Reverse osmosis filtering system for the purpose of reclaiming and re using Antifreeze back in the early 90s.
Water...PURE water (which does not exist) does not conduct. The contaminates in contained in the water do. The lower the Contamination the higher the resistance. So no matter how we are getting "Clean" water, Distilled or Deionized, we use that over Tap water from the garden hose.
Your mother knew this as she always had a gallon jug for her Iron. And she told you not to drink it......and that is why it is in the Grocery store.
One of the phosphate free Brands that I readily know is Sierra. But any brand that is PF will have the words proudly displayed on the front. They also will say "Aluminum Safe" on the front. Both of these will be justification for being twice the price as the one sitting next to it.
You can also look on the back and see if it is Propylene Glycol or Ethylene Glycol.
Propylene is what you want.
If you think about it That water absorbing contaminates over time...even in a sealed system....but it is not sealed as the coolant transfers back and forth from the overflow all the time.
So yes that stuff is getting more and more contaminated as time goes by. It'll keep it from freezing or over heating, but it still is a mini electrolysis lab experiment.
DEIONIZED WATER
Years ago, high purity water was used only in limited applications. Today, deionized (Dl) water has become an essential ingredient in hundreds of applications including: medical, laboratory, pharmaceutical, cosmetics, electronics manufacturing, food processing, plating, countless industrial processes, and even the final rinse at the local car wash.
THE DEIONIZATION PROCESS
The vast majority of dissolved impurities in modern water supplies are ions such as calcium, sodium, chlorides, etc. The deionization process removes ions from water via ion exchange. Positively charged ions (cations) and negatively charged ions (anions) are exchanged for hydrogen (H+) and hydroxyl (OH-) ions, respectively, due to the resin's greater affinity for other ions. The ion exchange process occurs on the binding sites of the resin beads. Once depleted of exchange capacity, the resin bed is regenerated with concentrated acid and caustic which strips away accumulated ions through physical displacement, leaving hydrogen or hydroxyl ions in their place.
DEIONIZER TYPES
Deionizers exist in four basic forms: disposable cartridges, portable exchange tanks, automatic units, and continuous units. A two-bed system employs separate cation and anion resin beds. Mixed-bed deionizers utilize both resins in the same vessel. The highest quality water is produced by mixed-bed deionizers, while two-bed deionizers have a larger capacity. Continuous deionizers, mainly used in labs for polishing, do not require regeneration.
TESTING Dl WATER QUALITY
Water quality from deionizers varies with the type of resins used, feed water quality, flow, efficiency of regeneration, remaining capacity, etc. Because of these variables, it is critical in many Dl water applications to know the precise quality. Resistivity/ conductivity is the most convenient method for testing Dl water quality. Deionized pure water is a poor electrical conductor, having a resistivity of 18.2 million ohm-cm (18.2 megohm) and conductivity of 0.055 microsiemens. It is the amount of ionized substances (or salts) dissolved in the water which determines water's ability to conduct electricity. Therefore, resistivity and its inverse, conductivity, are good general purpose quality parameters.
Because temperature dramatically affects the conductivity of water, conductivity measurements are internationally referenced to 25°C to allow for comparisons of different samples. With typical water supplies, temperature changes the conductivity an average of 2%/°C, which is relatively easy to compensate. Deionized water, however, is much more challenging to accurately measure since temperature effects can approach 10%/°C! Accurate automatic temperature compensation, therefore, is the "heart' of any respectable instrument.
Mr. ordinary guy with a little education out
Maybe someone would be willing to stand in a puddle of de-ionized water and test that for us. All water is a poor conductor but it still conducts electricity.
