Question(s) on Powdercoating Engine
Old Feb 14, 2008 | 04:29 PM
comp's Avatar
comp
Originally Posted by 88conv
First, let me correct myself on one point, outgassing is NOT caused by under or over curing a part. It IS caused by air entrapment in the casting. Preheating the part can help keep this from occuring however there are powders that are designed to allow the part to outgas. These are typically higher quality powders.
Second, what I was referring to with regards the subject of grounding, you are probably aware that powder is designed to be applied electrostatically requiring the part you are painting to be grounded. If you don't have a good ground, the powder won't stay on the part. You can cheat this by heating the part before you paint it. This causes the paint to pre-gel and stick to the part.
Go to www.powder-coaters.com to see more.
Finally, I am NOT a coater, but a supplier.
link didn't work
Old Feb 14, 2008 | 08:27 PM
99-ss-vert's Avatar
99-ss-vert
Originally Posted by comp
link didn't work
Sorry.. www.powder-coater.com Lots of info on this site.
Old Feb 14, 2008 | 08:50 PM
comp's Avatar
comp
Old Feb 15, 2008 | 12:50 AM
Curveit's Avatar
Curveit
Originally Posted by KevinRR
I've never slung mud all over the parts and then tried to remove it, but I don't see any real issues with it during normal use?
He's got a point... While the "wrinkle" paint does look good, it is a PITA to keep clean. I did a set of BBC valve covers back in the 60s; really looked nice with the orange motor. All those little valleys fill up with dust... quickly.
Old Feb 15, 2008 | 01:13 PM
countylawdog's Avatar
countylawdog
I had taken my cover (over the distributor) to the powdercoater a couple weeks ago. This way if I didn't like it - not expensive to get back to original.
After getting home and striping it - putting it on the engine ....... I'm excited now about getting the valve covers, tubes and plenum done.
Was really pleased the way it turned out!
Thanks for all the information ....... it really helped talking to the pc'er and understanding the process and the steps in getting to the final results.
Now we'll see how good I do smoothing out the magnesium valve covers.
