Need some info/help
Old Feb 15, 2008 | 02:32 PM
ajax_mp's Avatar
ajax_mp
Default Need some info/help
I have a 93 coupe.
Im assuming that if you leave your lights on and exit the car , you should get
some kind of reminder you left them on. a buzz or beep noise. My car does nothing.
also I just found out that when I was low on gas, the check gauges light comes on
but no noise to get your attention. What got my attention was the car hesitating as
I gave it gas.
I just wondering if this normal , or do I need to track down a bad fuse.
I did a search and didnt find anything with this issue.
any help would be appreciated.
Old Feb 15, 2008 | 02:55 PM
toptechx6's Avatar
toptechx6
Here is a link to the 93 owners manual
https://www.mygmlink.com/pdf/go2cont...93corvette.pdf
Old Feb 15, 2008 | 03:05 PM
dfalliaux's Avatar
dfalliaux
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
My car will not beep or ding. I figured this was normal.
Old Feb 15, 2008 | 03:08 PM
DaleD's Avatar
DaleD
My 87 will ding the same warning as keys in the ignition with door open.
Old Feb 15, 2008 | 03:58 PM
ajax_mp's Avatar
ajax_mp
Default help
Thanks for that online manual, It does say
There should be a chime if you leave the headlights on and turn off the ignition.
It does not say anything about a chime for low fuel. ( so i guess this is normal)
Now the question is "Why doesnt my car chime with the headlights on and ignition off"?
Everything else works , Im guessing that there wasnt a dedicated fuse for this.
The manual gives no further info on this matter.
Any ideas?
could it be a bad ignition switch?
Old Feb 15, 2008 | 06:50 PM
DaleD's Avatar
DaleD
You need a factory service manual. You need to find the chime in your car, there is a box that does that, and see if it's getting sent a signal. That's where I'd start.
Old Feb 15, 2008 | 06:54 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Got to get a FSM if you don't already have one.
Look on Fleabay, and make sure you get the manuals with the RED covers.
Old Feb 16, 2008 | 02:24 AM
sweetbaboon's Avatar
sweetbaboon
Why the FSM with red covers?
Old Feb 16, 2008 | 11:24 PM
RRT vette's Avatar
RRT vette
The white covers are the preliminary editions. They don't contain as much info as the red covers.
Personally I like mine to not chime in any vehicle. It gets annoying.
To Need some info/help
