Too much "wheel" time?
Old Feb 18, 2008 | 01:31 PM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
This so belongs in C6 section....
Old Feb 18, 2008 | 04:51 PM
Biggus Blockus's Avatar
Biggus Blockus
I vote this thread for Hall of Fame status.
This should go perfectly with other important Corvette questions:
How many coats of Zaino do you have?
Are those Lloyd floormats?
How much HP will my new shift boot add?
Old Feb 18, 2008 | 05:18 PM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Old Feb 18, 2008 | 05:54 PM
smack123's Avatar
smack123
Might be neck and neck with "Central Coaster tried to kill me!"
Cant find it...Apparently CC was kidding around and told some guy his car would stop better with his braking system filled half and half with water and brake fluid.
The guy actually did it and took 'er for a spin
ill never forget that one.
Aww sh*t - you mean I shouldn't have done that? I thought my brakes felt a little sloppy... Luckily going half/half on motor oil water is a well documented recommendation. In fact, i think I'll head out to the garage right now and fire her up!
Old Feb 18, 2008 | 06:02 PM
black_771's Avatar
black_771
Holy crap! Where can I get one of those? Does color matter?
Old Feb 18, 2008 | 06:11 PM
96VetteDriver's Avatar
96VetteDriver
Yes it matters - you need to match the red of your K&N intake to get the full 10% HP gain.
I think yellow is second at 8%.
Old Feb 18, 2008 | 06:16 PM
stick105's Avatar
stick105
You guys are too quick!!! I'll have to type slower next time!
Old Feb 19, 2008 | 12:52 PM
arandy's Avatar
arandy
St. Jude Donor '08
Originally Posted by PUNISHER VETTE
Same thing with merry-go-rounds. The outside seats/animals travel much farther/faster since the circumference of the circle is larger for them and therefore go faster to make the same turn in the same amount of time the inside seats do.
your outside tires travel much farther in the turn and therefore get out of sink with the inside ones.
This is why the outside horsies are for Vette drivers, and the inside horsies are all mustangs.
Old Feb 19, 2008 | 01:20 PM
VetteStir's Avatar
VetteStir
Finally a serious post in the C4 forum. The problem is, you probably didn't have the weight distributed correctly. Next time try it with someone sitting in the passenger seat or sit right in the center of the car on the center console.
Old Feb 19, 2008 | 01:26 PM
VIN_#_00521__Z-51_C4's Avatar
