sick 87 needs help
Old Feb 18, 2008 | 06:15 PM
bad87vette's Avatar
bad87vette
Default sick 87 needs help
my 87 previously failed smog check for high hydrocarbon and carbon monoxide. I tested the air diverter valve and switching valve using a 12v light bulb across the terminal both works fine. While trying to disconnect
the light bulb one of the wire touched the ground chassis, there was spark
then the light went out. After that I could not get anymore voltage reading on both diverter and switch valve connectors addition to that my battery will not charge anymore. I replaced the alternator, ECM, and battery. I checked the fuse box (right passenger side) all are ok. Is there
other fuses or relays I need to check. All this problem started when I accidently shorted the positive terminal of the air diverter switch valve.
Need help please !!
Old Feb 18, 2008 | 08:56 PM
The Beep's Avatar
The Beep
Sounds like you lost a ground.
Sorry you have to deal with all that smog testing global warming bs.
Old Feb 18, 2008 | 09:36 PM
VetteSlave's Avatar
VetteSlave
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Got the "service engine" light going in the dash? I'm thinking that you may have zapped one of the two relays on the firewall by the battery..........
Old Feb 18, 2008 | 09:43 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Check your fuseable links (Under the battery).
Old Feb 18, 2008 | 11:48 PM
bad87vette's Avatar
bad87vette
Default thanks all for you guick response
zr1fred, you're right one of the fuse link (red) got fried thanks so much
all it was a great learning from you guys. got it repaired everything back
to normal. As for the smog found a disconected host to the exhaust..
you guys are great....again many thanks all...
To sick 87 needs help
