Compressor
Old Feb 20, 2008 | 07:32 AM
marcus88's Avatar
marcus88
Default Compressor
How do you get the compressor to come to refill the freon, is there a jump wire of some sort.
Old Feb 20, 2008 | 12:51 PM
SunCr's Avatar
SunCr
New/rebuilt/repaired - you pull a vacuum and that will pull the first pound in. If it's low, clear any codes ('90 up) by disconnecting and reconnecting the battery, then (for any Year) jumper the low pressure switch harness with a paperclip which will keep it running while you're charging. For any Year, make sure the fan(s) is/are running - charge until the high side is to 2.2 to 2.5 times the ambient temp at the condensor.
