Front lowering procedure......
Old Feb 23, 2008 | 08:47 AM
Weav's Vet's Avatar
Weav's Vet
Default Front lowering procedure......
I need to lower my '96. I found this link http://www.digitalcorvettes.com/foru...ad.php?t=79763
Is this as good as any of the "How to's"? I know there is one on CF somewhere, just couldn't locate it. Thanks
Old Feb 23, 2008 | 08:56 AM
Iroc57's Avatar
Iroc57
Many of the members here post on the DC forum as well. That write up is quite good but I am not speaking from experience as I have not lowered mine(the traditional way anyhow)
Old Feb 23, 2008 | 10:53 AM
StealthLT4's Avatar
StealthLT4
The link you posted as well as:
http://webpages.charter.net/khasting.../lowering.html
are what I used to lower mine this past weekend. Read both, as neither guide is perfect, and both have some good tips that the other doesn't. Took me about 15 hours total, front and back. I probably spent about 3 hours experimenting with different techniques to cut the rubber from the spring; that was by FAR the hardest part of the whole project.
Also, on my '96, I HAD to disconnect the lower control arms in order to remove the spring. I guess since 96 had the softest suspension of all the years, the spring has to be more curved, since its a linear rate....anyway, it's a b!tch.
Lowering the rears honestly took about 20 minutes. It was a piece of cake.
Old Feb 23, 2008 | 02:22 PM
Weav's Vet's Avatar
Weav's Vet
Thanks JWALKER, I'd seen that link somewhere before but didn't save it. Looks like some cussing ahead! But I know I'll like the end result!
Old Feb 23, 2008 | 04:02 PM
StealthLT4's Avatar
StealthLT4
that's my attitude!
Old Jan 25, 2011 | 03:22 PM
Funrunner99's Avatar
Funrunner99
Are We Having Fun Yet!!
Default Dragging stuff????
So I have already bought the kit to lower the car but may do some of the mods spoken of to not have to glue on the new wedges. I have a 1990 Z51 Coupe that I guess has a slightly taller front air dam than the standard Coupe. I drag the air dam every now and then with the car at stock height. Do you guys run into big problems lowering the car or just every now and then like it is now. My car sits higher in the back than the front right now and it appears most of you lower the back more than the front to get the spacing above the tires about the same front & back. This would raise the front air dam slightly I guess and maybe that makes up for some of the drop. I love the way the cars look lowered and will do it either way, just wondered what peoples experiences are. This if my first Vette, have had it about a month and really, really like it. I also have a '68 Mustang that has been lowered 1.5-2" and when I put the new front valance on it may be running into this same problem. The car is street legal but I am also planning to run it in the Silver State Classic at some point, hence the suspension modifications. Thanks for all your help and advice!!! John
Old Jan 28, 2011 | 04:46 PM
turbotim23's Avatar
turbotim23
Well you can shorten your front spoiler about 5/8" to a 1". I decided to lower my front end as much as possible and was worried about my spoiler hitting coming into driveway so this is what I did. I measured my spoiler. The middle part was lower than side peices,probley from hitting things in the past. I took that off and bent it upward with a heat gun using heavy gloves. I put it between 2x4's kneeling on the 2x4's and heated edge next to them. I held it upward till it cooled locking the plastic back in place. It took a couple of times putting it back on the car till front and sides were even. Then I cut about anther inch off all the spoilers and sanded the bottom edge back nice and even with a sanding block . It's atleast 2 to 2 1/2 inches higher than it was. Good luck Tim
Old Jan 28, 2011 | 05:04 PM
jon0108's Avatar
jon0108
when my car was on the lift for an oil change, i used my mechanics air powered rotary cut off wheel to take an inch off my front spoiler. I used 1 inch wide masking tape for a guide. Took about 5 minutes
Old Jan 29, 2011 | 01:40 PM
turbotim23's Avatar
turbotim23
anther thing you can do is copy what the c5 corvette guys do and mount wheels on the skid frame at the lowest point where it normally drags. I got an idea how to do it and will try this this spring.
To Front lowering procedure......
