Power seat switch
Old Feb 27, 2008 | 06:27 PM
markjonesa's Avatar
markjonesa
Default Power seat switch
Hi guys. I've just been a Forum reader up until now, but I've got a problem. 1993 convertible. Console switch for power seat, drivers side stopped working. Every place I've checked, including the dealership, says it's discontinued and can't get it. Any ideas on where to find one???
Old Feb 27, 2008 | 06:38 PM
Greg Gore's Avatar
Greg Gore
Did you recently have the seats out cleaning uinderneath? Reason I ask is it is common to plug the wires back in backwards and that's how they act afterwards.
Old Feb 27, 2008 | 08:22 PM
markjonesa's Avatar
markjonesa
No taking the seats out. I know it sounds dumb but the switch works a little. The switch moves the seat up and down fine, it just doesn't move forward or backward unless I jiggle the switch and then it moves forward a little at a time. I'm afraid to move the seat forward / backward or the switch might completely go out and then the seat is stuck at that position.
Old Feb 27, 2008 | 08:58 PM
Greg Gore's Avatar
Greg Gore
Ok, That's probably the switch. I would check the C4 parts for sale & wanted forum. You'll usually find folks parting out cars there all the time. That switch is probably expensive new.
Old Feb 27, 2008 | 09:06 PM
CAP94's Avatar
CAP94
Check ebay
Old Feb 27, 2008 | 09:10 PM
MARKRUBYRED's Avatar
MARKRUBYRED
That does not sound like the switch but the power seat track. You can have them rebuilt by various vendors.
Old Feb 27, 2008 | 09:28 PM
Greg Gore's Avatar
Greg Gore
Mark, you're right about that. The seat tracks have a high failure rate on these cars. Plastic bushings inside eventually give up stopping operation in one direction. Sometimes you gan coax it to move if you get out of the car and pull on the seat in the direction you want it to go while pushing the switch. If that's it you could swap the seat tracks to put the good RS one on the LS if that's where you need it most.
Old Mar 12, 2008 | 06:32 PM
Vette Gator's Avatar
Vette Gator
I ran into this problem on my 89 (discontinued switches). I was able to take out the switches and open them up by unclipping the metal straps that hold everything together. The brass contacts on the pins had a black coating where the center rockers touched them. I used very fine grit sandpaper to clean up both the pin tops and the center rockers. No problems since then. The hardest part was to carefully pry off the copper strips to release the switches. I don't know if the 93 switches are the same.
To Power seat switch
