Another adapter question
Now that I am ready to get some adapters to fit the c5 wheels to my 86 I saw in the archives that there were people putting various sizes of adapters and mix matching the front and back.
So, my question is do I want just one inch spacers all the way around or what. What is going to look the best?
Also, would one inch spacers take me out past the long studd issue that many have commented on? If it does not, what does it look like to grind them down and does that ruin it for ever putting the factory rims back on?
The adapters will correct for the difference in offset between the early C4s and the later C4s and later generations, so you won't have rubbing in the wheel wells and the wheels will "look right" in your wheel wells.
The adapters should work as long as there is a recess in the C5 wheels that the adapter acorn lug nuts will fit into. Case in point, I can mount late C4 sawblades on my 87 with my adapters, but cannot mount C5 Z06 replica wheels because they lack this recess. I don't know about the C5 wheels you have in mind.
Do not skimp on quality when shopping for adapters; they are holding your wheels on!!! Make sure to torque them down the proper specifications!!! Try Vette Brakes and Products, Mid America, or Ecklers.
Here's another thread that is relevant to your question:
http://forums.corvetteforum.com/show...=wheel+adapter
This topic has been discussed extensively on the forum. More searching should provide you with plenty of other threads and additional information with which to make an informed decision.
I have autocrossed with the adapters and late C4 wheels without a problem. However, as with any large sampling of people, I'm sure there are others on this forum who have had negative experiences with wheel adapters. Good luck with your decision.
I measured it today with the wheels on there and the one inch seems like the way to go, as they are that recessed.
Thanks for the heads up, I was looking at some of them.
