Build Sheet Explaination
Old Feb 29, 2008 | 03:15 PM
Tim H.'s Avatar
Tim H.
Default Build Sheet Explaination
I bought a build sheet for my '94 Coupe recently.
What does the letters/initials and or numbers in the sections represent?
eg. Box 1(axle) has CQW in it.
Box 47(battery) has 655
Box 65(bumper height) has YAA etc. etc.
Thanks in advance.
Old Feb 29, 2008 | 03:46 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
it means you have an axle, a battery and a bumper. next.
Old Mar 1, 2008 | 08:51 AM
Tim H.'s Avatar
Tim H.
Forget your meds?
Old Mar 1, 2008 | 10:21 AM
c4cruiser's Avatar
c4cruiser
CQW refers to a complete axle assembly with a specific spring and gear ratio. I seem to recall that my old 92 'vert had a CQW sticker wrapped around one of the bars in the batwing. The car had FE1 base springs and a 2.73 (performance) rear axle. The workers used the axle codes to grab the specific assembly that was going into the car at that point.
Same goes for the battery code. As far a ride height, the YAA probably referred to a table for measurements required for that particular car. Not all Vettes had exactly the same ride height. Z07 cars sat a bit lower, 'verts sat a bit higher than coupes.
Old Mar 1, 2008 | 10:35 AM
Motsiv2's Avatar
Motsiv2
I believe box 47 (batt) 655 means how many cold cranking amps. By the way, love your car!
Old Mar 1, 2008 | 12:46 PM
All2kool's Avatar
All2kool
The RPO Codes for the numbers you gave are as follows, but this doesn't make sense. My .02.
655 : Trim Combination, Leather, Med Antelope (5) (91)
YAA : Tire Rear, P285/40zr17 Bl R/pe St Tl Hw4
To Build Sheet Explaination
