Odometer - Mechanical or Electronic?
Old Feb 29, 2008 | 05:05 PM
All2kool's Avatar
All2kool
Default Odometer - Mechanical or Electronic?
'86E. So I'm driving down I-5 today and decide I'll take advantage of the Speedometer Check. As I glance to see where the Odometer it is, it stops, as I am looking at it. That's just weird. About 12 miles later, it works again for a few miles, then quits. Started again a few miles later and then stops. Is the Odometer Electronic or Mechanical? Electronic Trip Meter and Speedometer working normally.
Old Feb 29, 2008 | 05:50 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
I'm ASSuming it's an electric mechanical. I know that the mileage won't turn if the car is not turned on.
Old Feb 29, 2008 | 05:53 PM
All2kool's Avatar
All2kool
But the car is turned on and traveling at 65mph - yet the Odometer is functioning intermittently.
Old Feb 29, 2008 | 05:56 PM
87 Ragtop's Avatar
87 Ragtop
I'm guessing you have odometer problems. I mentioned mine didn't work with the car in the "off" position to verify that it was electric and not solely mechanical. If it was 100% mechanical, it would turn whether the ignition was on or not. If your speed / trip odometer is still reading without dropping to "0" intermittently, then it's definately an odometer issue or problem with the connector to the circuit board.
Old Feb 29, 2008 | 09:23 PM
c4cruiser's Avatar
c4cruiser
The early C4's have a VSS (vehicle speed sensor) connected to the tranny output shaft and data is sent thru the ECM to the dash circuit board to an electronic motor that drives the odometer. It sounds like something is wrong in the motor.
Old Feb 29, 2008 | 09:30 PM
All2kool's Avatar
All2kool
So if there is a problem with the Odometer itself, would this affect the calculation for MPG? Honestly, this Odometer may have been malfunctioning for a few hundred miles and I have just not noticed. I have noticed that my Instant and Average MPG's seem to have dropped. Thinking I was out of tune, I changed the Spark Plugs and Air Filter just a few days ago (still have a few scabs on my right hand to prove that). If the Odometer stops intermittently, would this cause the MPG calculation to be incorrect?
To Odometer - Mechanical or Electronic?
