Automatic Transmition - No 3rd Gerar
Old Mar 2, 2008 | 06:40 PM
trulytex's Avatar
trulytex
Default Automatic Transmition - No 3rd Gerar
I am actually inquiring about a non-Corvette Car, but didn't know where else to ask. I have a 1975 Cadillac Eldorado (Front Wheel Drive) and it is not going into 3rd Gear - I checked the fluid and it seems to register too full. Any thoughts???? Thanks in advance...
Old Mar 2, 2008 | 06:55 PM
VinceC4's Avatar
VinceC4
you might want to try this forum..loads of caddy info
http://cadillacforums.com/forums/
Old Mar 2, 2008 | 06:59 PM
newbecorvetteguy's Avatar
newbecorvetteguy
Does it slip or does it just stay in 2nd? As I remember it, if it's not slipping, most of the time it's either the detent cable adjustment, vacuum modulator not working, or governor gear stripped,...and in that order. All control shifting. Check those out and then see what you got. The high fluid level shouldn't hurt anything on this transmission, but you might as well get it to the correct level anyway.
jmo
Old Mar 6, 2008 | 10:18 PM
trulytex's Avatar
trulytex
jmo
It doesn't slip, it shifts just like it is supposed to, just stays in second. It shifts smooth and at the usual speed.
To Automatic Transmition - No 3rd Gerar
