Disabling PKE light
Old Mar 6, 2008 | 11:27 AM
CozumelSteve's Avatar
CozumelSteve
6th Gear
Default Disabling PKE light
I don't have the key fob and dont ever care to use PKE. For 3 months no lights were on in the driver info area (except ASR off, of course), but while driving home the other day the PKE light came on and won't go off. I can temporarily turn it off while car engine is off by sticking key in ignition again and removing it, but it is always on while driving now. I tried pulling the PKE fuse but the light stays on. I just dont want to have to look at the light, so how can i disable it?
Old Mar 6, 2008 | 11:50 AM
Andrew's Avatar
Andrew
What year is your car? I am in the same situation as you are as I don't have a key fob!
I pulled the PKE fuse and the light went off. That is the only way I know how (at least it worked on a 96).
Old Mar 6, 2008 | 12:24 PM
lt4obsesses's Avatar
lt4obsesses
Disconnect the neg batter cable for 5 min then reconnect. Your ECM is throwing a code for some reason. This should clear it. You might go ahead and remove the fuse while battery is disconnected.
Old Mar 6, 2008 | 12:34 PM
CozumelSteve
6th Gear
Thanks.
I'll give that a try as soon as it quits raining.
Stupid rain spoils all my driving fun.
Old Mar 6, 2008 | 02:05 PM
MK 82's Avatar
MK 82
Take the bulb out.
Old Mar 7, 2008 | 09:49 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Easy fix. Pull the PKE fuse. One of the first things I did on my '93.
Old Mar 7, 2008 | 10:37 AM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Okay, that works if you want to turn the display lite off for the key fobe, how do you make it come on??? Checked the fuse, its fine, bought a fobe online, and have yet to figure out how to make it work. The display light in the panel doesnt lite up.
Old Mar 7, 2008 | 11:05 AM
lt4obsesses
The light probably doesn't come on because the PKE is not activited. The way we know if PKE is on is if the light comes on or not when we turn the ignition to the on position. Do a search in this forum and you will find out how to program the fob. Or you can take it to a dealer and they can do it for you, probably won't caost too much.
Old Mar 7, 2008 | 11:13 AM
vetter31's Avatar
vetter31
How to set up a fob with PKE is also in the owners manual for your car.
Old Mar 7, 2008 | 12:00 PM
dreamer2468
We have tried to trace the problem, but so far no luck, have looked in the manual, and all systems seem go, so may be a wire disconnected somewhere. The key is hard to turn in the lock sometimes, so wanted to get the keyless entry hooked up.
Oh well, will continue the quest til we get it figured out!
Old Mar 7, 2008 | 01:45 PM
MK 82's Avatar
MK 82
Can you say Hijack? It is easy to start your own thread.
Old Mar 8, 2008 | 12:27 AM
dreamer2468
Sorry, just thought I would jump in cause the advice I have got so far hasnt worked,,,,so will leave it at that. Thanks anyway!
To Disabling PKE light
