passenger
Old Mar 19, 2008 | 03:47 AM
Jonathon1990vette's Avatar
Jonathon1990vette
Default passenger
does anyone know what may be wrong? my passenger window will roll down only by the passenger switch, when i try to roll it down with the switch on the driver door i get nothing. any idea? wires, motor???
Old Mar 19, 2008 | 08:45 AM
Goldcylon's Avatar
Goldcylon
Well if the window operates on the passenger side using the passenger side window switch you have ruled out a bad motor as the window goes up and down. So my guess would be your drivers side switch for the passenger door has come loose from its socket, Needs to have its contacts clean or needs to be replaced. GC
Old Mar 19, 2008 | 08:50 AM
Harryscarlot's Avatar
Harryscarlot
Old Mar 19, 2008 | 09:17 AM
mdlfcrss's Avatar
mdlfcrss
Yup, what they said...
Old Mar 20, 2008 | 06:04 PM
Jonathon1990vette
ok thanks. ill go take off the panel and see what i can see. thanks again guys.
Old Mar 20, 2008 | 09:29 PM
thebeerman's Avatar
thebeerman
You don't have to remove the panel, just pop the switch out.
To passenger
