Faded Clear Coat Solution?
Old Mar 20, 2008 | 09:08 PM
CRVETTE92's Avatar
CRVETTE92
Default Faded Clear Coat Solution?
My clear coat around the side view mirrors and at he rear by my trunk is severely faded. Any solutions? I want to use Zaino but i think i should deal with the clear coat issue first. Thanks
92 BLK LT1 6SPD
Old Mar 20, 2008 | 10:41 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default faded paint
Whats Zaino?
Option 1. Machine buffing. If that doesnt work, option 2.
Option 2. Repaint areas affected with fading. DuPont cant make a dead on match to your paint if its the factory color.
Option 3 Repaint car.
Good luck!
Mike.
Old Mar 20, 2008 | 11:48 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
92 BLK LT1 6SPD
1 solution, repaint the car.
Randy
Old Mar 20, 2008 | 11:58 PM
CRVETTE92's Avatar
CRVETTE92
Zaino is a car wax system. I don't have the funds right now to repaint it.
Old Mar 21, 2008 | 12:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
W/Randy...Wait til you can afford to do it right..Once the clear starts going not much you can do. THeres always sanding and reclearing but why bother on old paint
Old Mar 21, 2008 | 03:38 AM
Silver fox in CA's Avatar
Silver fox in CA
5th Gear
Default The car is black- much simpler
Hi-
If the car is black, just repaint and clear the areas where you are having the problem- it won't work well with other colors, because they won't match- but black is black. My Dad had an old MG roadster, with individual fenders, and he was constantly being hit in parking lots- but the car was black- and each repaint just blended right in- and this was before sophisticated blending machines like they have now-
Try it on a mirror- I think you will be pleasently surprised-
Old Mar 21, 2008 | 07:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
If your painter can match different shades of black AND match the"old finish" (thats tricky) Id be impressed, hard to do if the paint is worn. Usually the whole panel if nothing else needs to be reshot.
Old Mar 21, 2008 | 02:16 PM
SunCr's Avatar
SunCr
Repaint - mirrors can probably be handled with a rattle can (or if you have a compressor, a detail gun and a pint from your paint jobber) assuming you do some prep and I'd remove them and the glass (it's just pops off) before you start. You'll still need to wet sand and buff, but that shouldn't be difficult. Unfortuanately, though the rest of the car may look good, it's probably faded somewhat too and an exact match may be impossible. Whatever you do, don't start slopping Armor All or similar on anything.
Old Mar 23, 2008 | 12:11 AM
CRVETTE92's Avatar
CRVETTE92
Thanks guys.
To Faded Clear Coat Solution?
