a/c blower motor not working
450 miles up the Nevada desert with no HVAC fan...ugh! Still gotta go back through NV or Death Valley..Aaarrrrrgh!!!
I pulled all 3 panel fuses to rest and nothing worked. I looked for codes in the fan control window...no codes. The manual says there's an UNDERHOOD fuse to protect the fan (blower) motor.
WHERE is it???????????
If the fuse were blown, the blower motor would continue to run even with the ignition off.
I'm looking at the schematic from a 90 service manual so the color code of the wires may be different from that of a 91.
The HVAC Programmer provides a DC input voltage on the Dark Green Yellow wire to the Blower Control Module.
The Blower Control Module outputs a voltage on the Purple wire which drives the Blower Motor.
The Blower Control Module is located inside the Evaporator housing. If you look on top of the evaporator housing on the engine side you'll see two electrical connectors that plug into the Blower Control Module. The Module is held in by some small bolts. Look at the two connectors for any burn marks.
Turn the ignition on, turn the fan on, with a voltmeter measure the voltage on the Yellow/Green wire which will vary from 2.5 to 7 volts depending on fan speed setting.
Output Voltage of the Blower Motor Control Module (Purple wire) goes to the Blower Motor and will vary from 4 to 12 volts.
Red wire is 12 volts to power the Blower Module and is hot at all times.
Black wire is ground.
To test the Blower motor itself, unplug the two pin connector and apply 12 volts direct to the motor.
You can also check Module Power - red - and though I don't know the ZR1 harness, that's usually battery - always hot.
'84 is a different animal with Manual Controls. You should start a new post, but check for a faulty relay or a short to voltage on the Power side (which should be red/black - not purple - for this Year).
