Sumitimo Tires
Old Mar 26, 2008 | 05:15 AM
Weav's Vet's Avatar
Weav's Vet
This is weird........I replaced my rotors yesterday. Before taking the tires off the front I jacked the car up and gave each front wheel a good shake in all directions to see if there was any movement that might be causing the shimmy. There was........outer tie rods need replaceing. So I said GREAT not a wheel issue then maybe. I just need to replace those and get an alignment and all should be fine. Put the new rotors on and in the process of burnishing them got up to the shake speed and guess what..........no shake!!! Just to weird..... Looks like another project to add to the list.
Old Mar 27, 2008 | 06:20 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Originally Posted by rickreeves1
I have a front vibration that started the day I installed 4 new Tomz wheels and 4 new Tirerack Sumitomo tires. I tried swapping a suspected bad rim with a new one I bought from Tomz. No luck there. No one can figure out the problem even on the Roadforce Hunter machine 3 times. I think the idiots at Firestone don't know how to work the thing. I spent way too much money on this already. I should have left it be. I guess the next step is trying new tires. I'm about ready to give up and sell all four tires and rims. I will be hard for me to ever buy tires and rims off the internet again. Too much of a headache.
Exact same problem here with the exact same vendor. I am going to buy Goodyears after I get my tax return... and hopefully that'll help.
Old Mar 27, 2008 | 04:31 PM
vetteblack's Avatar
vetteblack
Hopefully the goodyears will be back in production when you are ready to buy them. They are difficult to locate right now.
Old Mar 27, 2008 | 04:37 PM
WickedVetteLT4's Avatar
WickedVetteLT4
Im just gonna run Nitto 555's in front and the Nitto 555DR's in rear. When these wear out, ill buy the GS D3's next...
Old Mar 28, 2008 | 01:24 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
So... you're old rotors were a little warped and the tie-rods amplified the shimmy from the caliper-to-warped-rotor contact. Nice catch! Didn't you feel that amplified when braking?
I think I have a similar issue with my Jeep but it's on the rear. Much harder to imagine but I bet the rear axle bearings have a little slop. The cheap drums I bought probably aren't true. When I press on the brakes in that vehicle, the rear end sometimes shakes significantly.
(Every part on the rear brakes was replaced... cylinders, lines, shoes, springs, drums, everything).
Old Mar 28, 2008 | 04:28 AM
Weav's Vet's Avatar
Weav's Vet
[quote=GREGGPENN;1564749874]So... you're old rotors were a little warped and the tie-rods amplified the shimmy from the caliper-to-warped-rotor contact. Nice catch! Didn't you feel that amplified when braking?
Not that I noticed, Gregg. The brakes were a little soft, probably because of the old rubber lines but no pulseing at all. When I put the new rotors on I had a lot of pulseing. I'm hoping this is the old pads seating in and not these cheap rotors. The fronts are just about new and the rears probably have 10k on them. It's improving every day though. Maybe this might be the tie rod issue just showing up in a different spot. I hope to get the rods fixed next week so I guess I'll know then. These Summi's I'm running now are wider than the Firehawks that were on the car so maybe that has some effect on everything.
Old Jul 9, 2008 | 11:33 AM
eschoendorff
St. Jude Donor '08
Wish it was that easy for me.. brakes are new and NO pedal pulsing whatsoever....
Still haven't ponied up for the Goodyears.... other expenses came first. Wish I could stand to drive my Vette on long trips... I would just put the old (really old GSD3s) back on the car but one of the rims is cracked.
Until I get some $$$ together, I'm just gonna have to live with sub-par tires for a while...
Old Jul 9, 2008 | 01:09 PM
formerfoxbody's Avatar
formerfoxbody
Originally Posted by xrcrx
My rear 315's lasted 12k and that's with regular trips to the drags and auto-xing, the fronts are only half worn. Good tire for the money. No probs with balance all the way to 150+.
Old Jul 9, 2008 | 01:41 PM
eschoendorff
St. Jude Donor '08
Damn. See??? Now that's all I want...
Old Jul 9, 2008 | 02:26 PM
JEFNLSA's Avatar
JEFNLSA
Difficult? Try impossible...especially in 315's.
I just scored though...found a set of 315's (brand new w/ the stickers still on the tires!) in the C4 F/S forum. Got them for $450 + $70 shipping. That's $260 a tire shipped! Mine aren't even worn out yet but, considering you can't get a set of D3's in 315's anywhere, I jumped on this deal.
FWIW..Tirerack's price is $292 per tire + shipping, and they have no idea when they will even see them in that size. "On backorder from hell"
Okay, I'm done gloating.
Old Jul 9, 2008 | 02:35 PM
TA's Avatar
TA
Some have even said GY has no plans to make any more in that size
Old Jul 9, 2008 | 02:52 PM
JEFNLSA's Avatar
JEFNLSA
Well I haven't heard that but I did hear that GY wasn't even going to start producing them until the end of the year. Any way you look at it, 315/17's are becoming a rare breed. It's either Sumi's (just won't go that route on my car), Goodyears (or better yet good luck), or Vredesteins (which I've heard very little about). Other than that, it's drag radials...which I've considered.
In the meantime, I'm very lucky to have a fresh set of D3's in my garage.
Old Jul 9, 2008 | 05:19 PM
  #33
TA's Avatar
TA
Nitto is also making the NT555 (non drag radial version) in that size again
